7800X3D iGPU support?
alliance
33
5700X
Hi,
does the 7800X3D's iGPU work with Sequoia/Tahoe?
This will only be used for basic stuff like browsing the web, watching youtube etc, so it doesn't need to do anything GPU intensive.
I'm wondering whether I could use it on one of my machines and simply disable the 5070Ti in the config.plist file?
I'd simply have the onboard plugged in via HDMI to my monitor, and run the 5070Ti via DisplayPort, as that seems like the easiest solution?
Also, will this motherboard play nice?
I don't use onboard audio or ethernet, and I don't mind buying another AX210 PCI-E card for Wifi as required.
No, the IGPU is not supported in macOS.
The motherboard won’t run macOS without a compatible discrete GPU.
No idea if it is a good choice for a new Hackintosh system. What does it provide that you can’t live without?
Reactions: alliance
Ah fair enough, I will continue to use the hackintosh then :)
I just fancied having MacOS on all my machines, ha! :D
You can have macOS on all your machines… but you'd have to swap the 5070Ti for (or supllment it with) a supported or supportable AMD card.
