Hi,
does the 7800X3D's iGPU work with Sequoia/Tahoe?
This will only be used for basic stuff like browsing the web, watching youtube etc, so it doesn't need to do anything GPU intensive.
I'm wondering whether I could use it on one of my machines and simply disable the 5070Ti in the config.plist file?
I'd simply have the onboard plugged in via HDMI to my monitor, and run the 5070Ti via DisplayPort, as that seems like the easiest solution?
Also, will this motherboard play nice?
I don't use onboard audio or ethernet, and I don't mind buying another AX210 PCI-E card for Wifi as required.
