[EFI] [AN515-44-R4KA] Don't start boot Dmg
kaynnan
Ryzen 4600H
Hello everyone,
I am trying to install macOS on my Acer Nitro 5 (AN515-44), but I am persistently stuck at the [EB|LOG:EXITBS:START] line. The system freezes right after selecting the installer from the OpenCore menu.
Hardware:
  • Laptop Model: Acer Nitro 5 AN515-44
  • CPU: AMD Ryzen 5 4600H (Renoir, 6 Cores)
  • iGPU: AMD Radeon Vega (Renoir)
  • dGPU: Nvidia GTX 1650 (Disabled/Unsupported)
  • Bootloader: OpenCore (latest version)
The Issue:OpenCore loads, I see the boot picker, but when I select the macOS installer ("FAT external"), it scrolls through some logs and halts at [EB|LOG:EXITBS:START].
I noticed some errors in the log regarding OS.dmg.root_hash right before the freeze:[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF
What I have tried so far:
  1. Added SSDT-CPUR.aml to ACPI (and enabled in config).
  2. Applied AMD Vanilla Kernel Patches (modified the core count patch for 6 cores: B8 06 00 00 00 00).
  3. BIOS Settings: Secure Boot disabled (set Supervisor Password to disable it), Fast Boot disabled.
  4. Tried different combinations of Booter Quirks:
    • SetupVirtualMap: Tried both True and False.
    • EnableWriteUnprotector: False.
    • RebuildAppleMemoryMap: True.
  5. Added npci=0x2000 (and 0x3000) to boot-args.
  6. Kernel Quirk ProvideCurrentCpuInfo is set to True.
Log Output:
OpenCore Boot Menu (REL-106-2025-11-03)
1. NO NAME
> 2. FAT (external) (dmg)
(Shutdown| Restart|
Choose the Operating System: 0K
•CEB.LD.LF INJ O 1 ‹"(null string›"> ‹"1">
#IEB.B.SBSISZJ 723512
•LEBIB:SHA] <4bd14c937ab8905ad11d947ecfc336d16954a918>
#TEB.WL.PULNVIErr(0xE)<- RT.GV wake-falture 7C436110-AB2A-4BBB-A880-FE41995C9F82
#IEB.WL.DT|0] Err(OxE) <- EB.WL.PWLFNV
#IEB.WL.PWLFRTC |NONE]
#IEB.WL.DTI!] Err(QxE) <- EB.WL.PWLFRTC
#IEB.LD.LKCIR.1] ("System \Library\KernelCollections\BootKernelExtensions.kc">
#[EB.LD.LKFS|-7] Ok(0)
#IEB.LD.LKCJ-7] Ok(0)
#IEBIBST:REV1]
#TEBICSR:OUT] 0x00000040
#[EB.BST.FBSI+]
#IEB|GIP:PHS.1] Boot 1
#IEB.BST.FBS|ADSZ1 0
#TEB.BST.FBS KSSZJ 0
#[EB|SB:SBGMFNS] x86legacyap. im4m
#IEBIRH:PF] usr|standalone\OS.dng.root_hash
#LEBIRH:NF1 <"usr||standalone|\05.dmg.root_hash.x86legacyap.2m4m">
#CEB.LD.LF|IN] © 1 ‹"usr||standalone|\OS.dmg.root_hash"> ("0*)
#IEB.LD.OFS/OPEN!] Err (OxE) ("usr||standalone|\OS.dmg.root_hash™>
#IEB.RH.LRHIP!] Err(0xE) <- EB.LD.LF
#IEB.BST.FBSI1] Err(0xE) <-EB.RH.LRH
#IEBILOG:DT] 2026-01-23T23:28:29
#[EB LOG:EXITBS:START 2026-01-23123:28:29
Hello everyone,
Hardware:
I noticed some errors in the log regarding OS.dmg.root_hash right before the freeze:[EB.LD.OFS|OPEN!] Err(0xE) &lt;"usr\\standalone\\OS.dmg.root_hash"&gt;[EB.RH.LRH|P!] Err(0xE) &lt;- EB.LD.LF
Log Output:snow rider 3d
1. NO NAME
(Shutdown| Restart|
#IEBIBST:REV1]
#[EB.BST.FBSI+]
Have you checked the compatibility of your hardware components with macOS, specifically the AMD Ryzen CPU and Radeon Vega iGPU
