macOS Tahoe on Asus RoG Zephyrus G14 laptop
mapomme1108
21
Hello,
I have followed a guide from another hackintosh website to create an OpenCore folder
With this OC folder, I can boot the installer and do the first part of the installation
There is the screen with "About xx minutes remaining", then it reboot and the pc
is stuck in a reboot loop
The last message before it reboot is :
"IOPlatformHaltRestartAction -> AppleSMC"
I don't know what to do to make it work
I have attached my OC folder
Thank you for your help :)
Have you ever run a previous version of macOS on your G14 laptop? If not, then I would suggest you look to install Sequoia or Sonoma before trying to install Tahoe. Tahoe has too many current issue, whereas the others are more mature and less prone to kernel panic once you have a compatible EFI.
Try the attached EFI with Sequoia, see if it gets you any further.
Hello,
I already run macOS Sequoia with the attached EFI folder
Your EFI folder does not work with Sequoia on my PC, it is stuck on this
Hi, try this OC for Sequoia to see if it works for you.
@Guantanamera : Thank you, with your OC folder, Sequoia does a kernel panic and Tahoe is stuck at the beginning of the boot process of the usb installer
@me93w : I am not successfull in launching Tahoe.
I will keep trying
I will keep trying
Try this other one in sequoia... good luck
