Need help installing macOS on AMD Ryzen 7 9800X3D
unclesam
42
12
HongKong
Ryzen 9900X
Hello everyone,
I need some help with installing macOS 15.7.1 on my AMD Ryzen 7 9800X3D system.
Here are my basic hardware details:
  • CPU: Ryzen 7 9800X3D
  • Motherboard: ASUS TUF B850M-Plus WiFi7
  • GPU: Radeon RX 6600 XT
  • RAM: 64GB DDR5
  • NVMe SSD: Micron Cruical P510 1TB
Here’s what I’ve tried so far:
  • I used the SysReport tool from OpenCore Debug version on this machine to dump the ACPI tables, including SSDT-EC, SSDT-HPET, SSDT-USBX, and SSDT-PLUG-ALT.
  • Then, I combined them with the EFI that previously worked on my Ryzen 9 9900X + ASUS B850 setup.
  • I double-checked all BIOS settings to make sure nothing was misconfigured (e.g., CSM disabled, Above 4G Decoding enabled, etc.).
However, I ended up with the following boot screen (see attached image).
At this point, I still cannot enter the macOS installer.
I’ve uploaded my config.plist for review — I’d really appreciate it if anyone could help check my config.plist, kernel patches, USBMap, and ACPI setup.
Thanks a lot for your help and guidance! 🙏
Hello everyone,
  • RAM: 32GB DDR5
  • NVMe SSD: T-FORCE Z4 1TB
to start you left corecount of your previous CPU (12 cores i think)
9800x3d has 8!
Reactions: unclesam
Hi @fabiosun
Thanks for taking the time to reply!
I really appreciate your work and all the guidance you’ve shared.
Its WORK now. 😊
Reactions: fabiosun
I'm currently stuck at the macOS13 or 15 installer — the installation starts normally, but it always freezes midway through the process.
I've tried several times and it always stops at the same stage.
This is the first time I’ve encountered this issue — I’ve installed macOS many times before and never had this problem.
Does anyone have any suggestions or possible causes I should look into?
Thanks in advance for your help!
Post your EFI and exact hardware you have in your build :)
cpu: amd 9800x3d
mb: asus tuf-b850m-plus wifi7 w
ram: t-force ddr5 16gb*4
gpu: msi rx6600 xt 8gb
nvme ssd: micron crucial p510 1tb
sata ssd: intel 480g
@unclesam why do you disable USB mapping?
@fabiosun
I wanted to share a quick update.
My original plan was to make sure macOS 15 could be installed and run stably before doing the USB mapping process.
However, I ended up completing the USB mapping during a break in the installation process anyway.
After some testing, I found that the installer freeze issue was actually caused by my Micron Crucial P510 1TB NVMe SSD.
No matter which M.2 slot I used on my TUF B850M-Plus WiFi7 motherboard, the installation would always hang.
It seems that this SSD has some compatibility issues with the B850M platform.
Interestingly, when I tested the same P510 SSD on another motherboard (Intel B560M), it worked perfectly fine — no freezes or errors at all.
After switching to a different NVMe drive T-Forece Z4 1tb on the B850M board, the macOS installation went through smoothly and everything is now working great.
Thanks again for all your help and guidance!
@unclesam i asked in previous message your exact hardware because some doubts i had on usb or nvme used
my curiosity is if an installed OS in that disk works well in new B850M platform (bypassing installation steps which hangs in that chipset/motherboard)
Update:
To double-check, I reinstalled the Crucial P510 back into my TUF B850M motherboard today — and surprisingly, the macOS installation worked perfectly fine this time.
It seems that whatever issue caused the previous installation freeze has somehow been resolved, although I’m not entirely sure what changed.
Anyway, my P510 NVMe and TUF B850M are now getting along just fine. 😄
Update:
Could you post some speedtest for it?
very curious because it was very rare to have success in OSX with a gen 5 nvme :)
PCI initialisation/enumeration could be a suspect. Is the P510 used by macOS? Is it installed in the same slot as before? Are there changes in other PCIe devievices?
Reactions: Edhawk
I'd like to share an update from today’s testing:
Currently, with the P510 installed in the M2_3 slot, the system works very well. I also ran a speed test — the read speed is about 7100 MB/s, and the write speed is around 6600 MB/s.
However, when I install the P510 in the M2_1 slot, macOS15 cannot be installed properly, and even if I boot from an already installed macOS15 system, it becomes unstable and crashes within about 2~3 minutes.
Reactions: fabiosun
@unclesam so it seems NVME gen 5 works well only on M2 Gen 4 ruled from B850 chipset and not for Slot ruled from AMD CPUs (7/8/9000) series
M2_3 is a PCIe 4.0 slot served by B850.
M2_1 is a PCIe 5.0 served directly from CPU lanes.
So it could be an issue with 5.0 speed.
Out of curiosity, have you tried M2_2 (4.0 on CPU lanes)?
Today’s test update:
When installing the P510 in the M2_2 slot, the macOS15 system still couldn’t boot or run properly.
After that, I tested a T-Force TM8FFJ001T (NVMe Gen5 SSD) in the M2_1 slot — it worked fine, with benchmark results showing read speed around 10,000 MB/s and write speed around 8,600 MB/s.
Based on these tests, my preliminary observation is that the issue may be related to compatibility between the P510 NVMe and specific M.2 slots on the motherboard.
Reactions: etorix and fabiosun
