Humour me
keef247
102
25
28
OK, so I updated my EFI to contain the latest OpenCore and Kexts.
I then wasted an hour with the seriously lacking guide for USBMap off the Github page:
This seems to lack quite a lot of info :(
For a start, does it actually save/update my existing USBMap file in it's original location, once I've updated it? Or does it place it somewhere? It doesn't add another to the Results folder, unless you choose a different option.
Regarding the USBMap files, I used USBToolBox original for Sequoia and previous OS versions - I've never had a problem?
So all I have relating to USB mapping kexts, are USBToolBox.kext and UTBMap.kext - that's it?
When you goto update/modify the files using USBMap.command, it doesn't seem to mention these files but does support opening them in USBMapInjectorEdit.command ?
What I want to know is, are the USBToolBox.kext and UTBMap.kext files even supported in Tahoe? Or do I mess with them in USBMap.command and export them with the same filenames I currently use i.e. 'USBToolBox.kext and UTBMap.kext'?
When watching or reading any guide, they simply mention pasting the modified version of 'USBMap.kext' into your kexts - I've never had this file? Only the aforementioned above files?
Then what, do you then use ProperTree (what I always use) to do a CleanOCSnapShot like before with these files and add the entries to update the config.plist to support Tahoe?
The Github guide for USBMap is honestly so lacking and rubbish, it goes so vague when it comes to updating the config.plist and conflicts with what I've red on other guides?
I'm properly stuck here! It's very frustrating as this shouldn't be hard to do?
When I try and boot off the installer, I just get a No Entry symbol with apple.com/support - which obviously doesn't tell me anything.
Also I've red elsewhere that using IntelBluetoothPatcher, could cause issues running the installer or Tahoe itself - something I need to use.
Even if I create this USBPorts.kext - what do I do with it once I've pasted it into my Kexts folder and preformed a 'CleanOCSnapshot' in ProperTree? As I never had this file before, as I was using USBToolBox.kext and UTBMap.kext - so how will my EFI/config.plist know what to do with it, or the installer?
@Edhawk @Shaneee any ideas mate?
No, as they lack the additional USB port entries required for Tahoe.
This is a screenshot of my old USBMap.kext for my Asus X570 system. Showing the first USB controller XHC1.
Screenshot 2025-09-23 at 18.45.26.png Works in Catalina to Sequoia, but not in Tahoe.
This is a screenshot of my new USBMap.kext for the Asus X570 system. Showing part of the first USB Controller XHC (previously was named XHC1).
Screenshot 2025-09-23 at 18.45.47.png Works in Catalina to Tahoe.
You can see the highlighted entries in the new USBMap.kext/Contents/Info.plist. These are required for the ports to work in Tahoe.
Neither USBPorts.kext or UTBMAp.kext add these additional entries, so neither USB kext will work in Tahoe.
Using USBMap is very similar to using USBToolBox Tool in Windows. As USBToolBox Tool was a Windows clone of the USBMap script. If you know how to create a UTBMap.kext then you already know how to generate a USBMap.kext. The instructions in the script Terminal window are nearly identical.
When you have created the new USBMap.kext simply, which will be generated in the 'Results' folder within the USBMap-Master folder, copy it to your /EFI/OC/Kexts folder and add an entry for the kext to your config.plist.
You will need to remove the USBToolBox.kext and UTBMap.kext files and config.plist entries, as you should never use two USB configurations in your OC setup.
The Error message you are seeing is USB related, basically the system drops the USB port you are using to install macOS Tahoe and so the installation kernel panics. You could try using a different USB port to see if the installation continues. A USB 2 port would be the best option, if your motherboard contains one on the rear I/O plate.
It is commonly advised to use a really pared down set of kexts in OpenCore when installing macOS Tahoe. To prevent any issues. Any kext you remove can be added back once you are on the Tahoe Desktop. Problematic kexts include but are not limited to to the following:
  • WhateverGreen.kext
  • AppleALC.kext
  • Bluetooth kexts
  • Sensor kexts
AppleALC.kext can't be added to the OpenCore setup, as Apple have dropped the use of AppleHDA.kext from Tahoe. There is a work around for this issue. But you need to get Tahoe installed before you attempt that fix. I have attached a link on how to fix the AppleHDA issue in Tahoe.
View attachment 18065 Works in Catalina to Sequoia, but not in Tahoe.
View attachment 18066 Works in Catalina to Tahoe.
  • AppleALC.kext
  • Bluetooth kexts
  • Sensor kexts
Thanks mate. OK, so I did do some of this but might not have explained it very well lol :) Sorry about that.
So TLDR, I've already made that USBMap.kext earlier in the Results folder.
Can I simply, delete the USBToolBox.kext and UTBMap.kext and then use Propertree to perform a clean-oc-snapshot, and that'll remove the entries, right?
Then with the newly created USBMap.kext put into my Kexts folder and doing the same thing in Propertree, it should add it to my config.plist - right?
Or use one something like OCAuxileryTools to open my config.plist, and tick the kext for USBMap.kext, save, and then it should 'just work'?
If I use USBMap to make the kext, I take it I don't have to mess about doing the following that I red in another guide:
5. Replace com.apple.driver.AppleUSBMergeNub with com.apple.driver.AppleUSBHostMergeProperties in CFBundleIdentifier and AppleUSBMergeNub with AppleUSBHostMergeProperties in IOClass.
6. Locate IOKitPersonalities and expand ports under IOProvideMergeProperties. You should have something like following
7. Create two New Child with the name usb-port number and usb-port-type in each of the ports (HSXX and SSXX) defined in the mapped kext and set the Class (value type) as Data for usb-port-number and Number for usb-port-type.
8. Match the value with that of the existing configuration i.e. UsbConnector with usb-port-type and port with usb-port-number as explained above. For example, the HS03 has UsbConnector set as 3 (USB 3.0) and port as 03000000 respectively. Similarly, change the values to the new key to match yours.
As USBMapTool, will have done this for me right? Or do I still have to mess about adding stuff to the config.plist myself, despite using USBMapTool to adjust the USBMap.kext file to suit Tahoe?
EDIT:
I forgot to say, I have my onboard LAN and soundcard disabled, and simply use my graphics card's HDMI and DP for sound - so can I delete AppleALC.kext and remove it from my config.plist?
I have WhateverGreen, VirtualSMC, Lilu, itlwm, IntelBTPatcher, IntelBluetoothFirmware, BlueToolFixup, AppleReporterDisabler, and AMDRyzenCPUPowerManagement kext's in my kext folder - so do I even 'need' WhateverGreen, VirtualSMC, Lilu, for a 5700X, B450i, RX 6800?
Thanks again for your help mate!
EDIT:
YES.
YES.
You could do both at the same time, i.e. only use the OC Clean Snapshot once to undertake both the add and delete actions.
Nothing else is required when using the latest release of USBMap.kext. Just generate the kext with the ports set correctly, then add the kext to your OC setup and it will work in macOS.
Do not use the option to generate the Legacy kext in USBMap. You don't need it in your AMD system running Sequoia or Tahoe. It is for older versions of macOS, such as High Sierra and Mojave.
  • Love
Reactions: keef247
YES.
YES.
Sweet, I'll try that in a second, thanks dude!
Regarding my edit,
YES.
You only need the following kexts.
  • Lilu.kext
  • VirtualSMC.kext
  • AppleReporterDisabler.kext
  • Your Ethernet controller kext
  • Your USBMap.kext
If you use WiFi for internet access you probably won't be able to use it during the installation, as Itlwm.kext won't work without the Heliport app being installed first.
Use a Wired mouse and keyboard or a combo setup (Logitech or similar) that uses as specific USB dongle. Do not use a keyboard and mouse that requires the Intel Bluetooth to be working.
Everything else is fluff that can be added to the OC setup after the macOS Tahoe installation has completed.
You need to watch for the FileVault option during the later stages of the installation process. Make sure you unselect the option to use FileVault on your macOS Drive. If you miss this option, i.e skip past the tab, you will regret it.
I would recommend not using the iCloud sign in option during the installation Wizard, it can throw up some issues that are completely unnecessary. Just create your local account and sign in to iCloud once the installation has completed.
  • Love
Reactions: keef247
YES.
  • Lilu.kext
  • VirtualSMC.kext
  • Your USBMap.kext
None of that worked mate.
Mapped the USB ports selecting only 9 out of 18 that displayed. Made sure I selected the 9 that displayed after swapping in/out USB2/3 devices into each port individually.
Removed all the other Kexts and just left: Lilu, VirtualSMC, AppleReporterDisabler, and USBMAP.
Updated those kexts to the latest, along with the latest OpenCore, performed a Clean OC Snapshot with Propertree.
Same BS issue with the no entry symbol.
What a joke.
Why only 9 of the 18 USB ports?
You aren't limited to 15 ports. Your AMD system will have 2 or more USB controllers and each controller can activate 15 x ports. You should be activating all the ports you had active in your UTBMap.kext.
I have assumed the following:
  1. You have the latest Tahoe compatible AMD Kernel Patches in your config.plist.
  2. You are using OC 1.0.5
  3. You have the latest versions of the essential kexts in your Kexts folder.
  4. You are using MacPro7,1 SMBIOS, as iMacPro1,1 system definition has been dropped for Tahoe.
Post a copy of your EFI folder with the Serial Number deleted/redacted from the config.plist.
If you have a good USB map for earlier versions, the easiest way should be to edit the plist it contains to add the usb-port-type and usb-port-number entries for Tahoe, as shown by @Edhawk 's screenshots.
Ah OK, well I'll try it with more ports :)
Yep everything up to date, but the SMBIOS is named iMacPro19,1 - so just generate a new one as a MacPro7,1 then it'll work?
Is it true that you have to plug in 1 USB 2.0 then 3.0 device in each port, 1 at a time after each 5 second pass? As some guides say to, and some don't?
Will GenSMBIOS change my existing system definition without me having to make an entire config.plist from scratch - it's been a while since i've used it :)
Yeah, that didn't work, that's what I tried first :(
iMac19,1 isn't supported in Tahoe.
If you want to use an iMac SMBIOS you need to use iMac20,1 or iMac20,2. As they are the only 2 x iMac SMBIOS that work in Tahoe. Apple have dropped all the others.
You have to plug in a USB2 and a USB3 pen drive/device to discover all 18 x ports. Each port needs to be tested, some ports will only work with USB2, some will require testing with both USB2 and USB3.
If you have any Type-C ports on the front or rear of the case, then you need a test them with a Type-C device, if you plan to include them in the kext.
This is the method I use to configure the USB ports.
USB2 (0) - Physical USB2 ports on rear I/O plate, these ports always have a Black coloured tang.​
USB3 (3) - Physical USB3 ports on rear I/O plate, these ports can have a Red, Blue, Yellow or Cyan coloured tang.​
Virtual USB2 ports - served from physical USB3 ports should be set the same as the physical port​
USB3 (3) - Motherboard Header, usually serving the case front USB3 ports.​
Internal (255) - Motherboard USB2 header, this will be any device served from a header port, such as Bluetooth module, case front USB2 ports, case front card reader etc.​
Internal (255) - Built-in M.2 WiFi/BT connector, motherboard LEDs and CPU Cooler USB connection.​
Type-c+sw (9) - will only show two ports being available, 1 x Physical Type-C and 1 x virtual USB2 port.​
Type-c (10) - will show 4 x ports being available.​
This occurs when the Type-C device initially inserted, then removed, is flipped 180° and reinserted in the same port, 2 x Type-C and 2 x virtual USB2 ports.​
Using GenSMBIOS to generate a new iMac20,x SMBIOS is what I would do.
You need to copy the Serial Number, MLB, ROM and SystemUUID from the Terminal Window to the PlatformInfo > Generic section of your config.plist, overwriting your current SMBIOS data.
As always make a copy of your current config.plist before overwriting anything.
Unless you are running a Clean installation of Tahoe on another drive, i.e. not updating your current macOS Sequoia drive. I would recommend signing out of iCloud, Music, App Store, Messages and FaceTime before you change the SMBIOS. Otherwise you could end up with issues signing in to iCloud etc.
I have a couple of test systems running Tahoe. I don't intend to keep them running that OS. I will be reverting them back to just Sequoia and Windows 11. It might be worth another look in a month or two, when Apple have got around to fixing the bugs and other crap they have provided (Safari 26!).
In my opinion Tahoe n it's state offers nothing over Sequoia, in fact I think it is a step backwards compared to 15.6.1.
Do you know if Whatevergreen, Bluetoolfixup and Heliport are working?
