OK, so I updated my EFI to contain the latest OpenCore and Kexts.
I then wasted an hour with the seriously lacking guide for USBMap off the Github page:
github.com
This seems to lack quite a lot of info
For a start, does it actually save/update my existing USBMap file in it's original location, once I've updated it? Or does it place it somewhere? It doesn't add another to the Results folder, unless you choose a different option.
Regarding the USBMap files, I used USBToolBox original for Sequoia and previous OS versions - I've never had a problem?
So all I have relating to USB mapping kexts, are USBToolBox.kext and UTBMap.kext - that's it?
When you goto update/modify the files using USBMap.command, it doesn't seem to mention these files but does support opening them in USBMapInjectorEdit.command ?
What I want to know is, are the USBToolBox.kext and UTBMap.kext files even supported in Tahoe? Or do I mess with them in USBMap.command and export them with the same filenames I currently use i.e. 'USBToolBox.kext and UTBMap.kext'?
When watching or reading any guide, they simply mention pasting the modified version of 'USBMap.kext' into your kexts - I've never had this file? Only the aforementioned above files?
Then what, do you then use ProperTree (what I always use) to do a CleanOCSnapShot like before with these files and add the entries to update the config.plist to support Tahoe?
The Github guide for USBMap is honestly so lacking and rubbish, it goes so vague when it comes to updating the config.plist and conflicts with what I've red on other guides?
I'm properly stuck here! It's very frustrating as this shouldn't be hard to do?
When I try and boot off the installer, I just get a No Entry symbol with apple.com/support - which obviously doesn't tell me anything.
Also I've red elsewhere that using IntelBluetoothPatcher, could cause issues running the installer or Tahoe itself - something I need to use.
Even if I create this USBPorts.kext - what do I do with it once I've pasted it into my Kexts folder and preformed a 'CleanOCSnapshot' in ProperTree? As I never had this file before, as I was using USBToolBox.kext and UTBMap.kext - so how will my EFI/config.plist know what to do with it, or the installer?
@Edhawk @Shaneee any ideas mate?
GitHub - corpnewt/USBMap at tahoe-test
Python script for mapping USB ports in macOS and creating a custom injector kext. - GitHub - corpnewt/USBMap at tahoe-test
