You need to set a MaxKernel of 24.99.99 for your IOSkywalkFamily block, IOSkywalkFamily,IO80211FamilyLegacy and AirportItlwm injection. Have you also updated NootRX for Tahoe as it won't work without some changes.
Check that the USB port used to connect the Bluetooth to the system is correctly configured, ie set as 'Internal'.
You can have the correct kexts, Nvram settings etc. in your OC setup and still your Intel Bluetooth not work because the USB connection is set incorrectly.
Do not use Hackintool for configuration of your AMD USB ports, use either of these tools.
Corpnewt's USBMap script in macOS
