Sonoma Aorus X570 Elite (No wifi) Ryzen 5 5600x OC1.0.2 EFI
Sasaf01
5
Amd 5600x
Build
CPU ryzen 5600x
Motherboard X570Aorus-Elite Bios:F40d
Ram:32gb 3600 MHz
GPU: ASRock Rx6900xt
SSD: 500gb
I built my EFI following the opencore guide step by step, after verbose mode I get to the installer, initialize the disk as apfs, guid partition map. I start recovery and it doesn't load the license terms (see picture 1)(I don't know if this is relevant), nevertheless I continue the installation.
After 2 hours of installation it performs the first reboot, and this is where it stops me. as soon as I reboot, I select boot from EFI and run ''macOS Install'' (not the starting dmg file, but this one that comes out after installation), runs the verbose mode and then restarts in a loop, I always select ''macOS Install '' looped without achieving anything
I've been trying for over a week now.
Also I tried to build my ACPI with SSDTTIME using SSDT EC and SSDT USBX instead of the prebuild but i got the same result.
I attach my EFI.
Thanks in advance for your time and help
I attach the report files
  1. Which version of macOS Sonoma are you trying to install?
  2. From where did you download the Sonoma installation app?
    1. Did you use Corpnewt's gibmacOS script to download the Sonoma installer?
Can you upload your EFI in a Zip format instead of using the RAR format.
1= the recovery file makes me install sonoma 14.7
2= in using the macrecovery file from opencor
Btw i have solved the problem. Now im doing the post install.
I will update this post with all the upgrades.
Build
CPU ryzen 5600x
Ram:32gb 3600 MHz
SSD: 500gb
I attach my EFI.
I also encountered this problem but don't know how to fix it.
