Build
CPU ryzen 5600x
Motherboard X570Aorus-Elite Bios:F40d
Ram:32gb 3600 MHz
GPU: ASRock Rx6900xt
SSD: 500gb
I built my EFI following the opencore guide step by step, after verbose mode I get to the installer, initialize the disk as apfs, guid partition map. I start recovery and it doesn't load the license terms (see picture 1)(I don't know if this is relevant), nevertheless I continue the installation.
After 2 hours of installation it performs the first reboot, and this is where it stops me. as soon as I reboot, I select boot from EFI and run ''macOS Install'' (not the starting dmg file, but this one that comes out after installation), runs the verbose mode and then restarts in a loop, I always select ''macOS Install '' looped without achieving anything
I've been trying for over a week now.
Also I tried to build my ACPI with SSDTTIME using SSDT EC and SSDT USBX instead of the prebuild but i got the same result.
I attach my EFI.
Thanks in advance for your time and help
I attach the report files
CPU ryzen 5600x
Ram:32gb 3600 MHz
SSD: 500gb
I attach my EFI.
