Regarding AMD platform sound card driver issues in macOS Sequoia(The latest version AppleAlc 1.9.3 problem has been solved)
mmp369
66
15
AMD Ryzen 3 2200G
Brand: MSI
Model: MSI MS-7B89 Desktop
CPU: AMD Ryzen 7 1700
GPU: AMD Radeon 580 Series Xunjing (Songjing) 8GB ( Separate GPU mode)
HDD: Jintek SSD 256 GB
Name: Ruiyu RTL8168/8111/8112 Gigabit Ethernet Controller/Microstar
Network card type Wired network card
Main board: MSI B450M MORTAR MAX (MS-7B89) (LPC Controller B450 chipset)
As shown in the figure below, the audio device is not displayed in Hackintool, but the sound card device exists in PCle. At first, it was suspected to be an IRQ conflict problem, but the sound card driver is normal under the macOS Sonoma system. AppleALC is just a Lilu plug-in patched for AppleHDA, but in AppleHDA is not loaded under the macOS Sequoia system, so AppleALC directly loses the Patch target, and kextstat shows that AppleALC loading has no effect.
Reactions: ccphuc
Try this more simple if you have been issues. Its same script but you need gave permissions manually, need remove AppleALC.kext from EFI folder and not put any kext to audio in there. VoodooHDA will be installed in Library / Extensions with package installer script.
My original same script is here in insanelymac: Voodoohda installer script by Max.1974
Open Terminal in macOs and type:
sudo -i
password: ****
cd <drag your folder with scripts>
drag makeInstall.sh and type enter
its done!
Now just run VoodooHDA.pkg
Works to me for Clover and Opencore.
Check SIP recommended
* SIP Clover 0xA87
* SIP Opencore 850A0000
Zip files:
VoodooHDA Kext 3.0.2 Git Hub
New video tutorial detailed:
Non funziona a me ho un desktop da premettere
Run terminal
sudo -i
password: ****
its done!
Now just run packages
Opencore is: 850A0000
that works like a charm
Reactions: Max.1974
Thank you! Enjoy it
(PT-BR Obrigado meu irmรฃo !! )
YES! It works beautifully well! I have an ASUS and a Gigabyte with the same codec and now they work fine.
Thanks a lot.
Reactions: Max.1974
Thanks a lot.
God bless you all! Thank you !! Enjoy it !! ๐Ÿ˜Žโœ”๏ธ๐Ÿคฉ๐Ÿ€
@genny
I'm sorry for not explaining, I use my Gigabyte Aorus Z790 Desktop with the VoodooHDA and it's more perfect than on my Laptop.
The VoodooHDA installation doesn't care about your SMBIOS or updates, if it's supposed to work, it will work.
I explained it step by step, but it doesn't seem like you followed it. You cannot leave any Audio Kext or the AudioDXE.efi driver in the drivers folder.
Here's a video from a friend in full.
VoodooHDA or AppleALC?
This is my Desktop with VoodooHDA
Hardware Overview:
Model Name: Mac Pro
Model Identifier: MacPro7,1
Processor Name: 13th Gen Intel(R) Core(TM) i9-13900K
Processor Speed: 3,0 GHz
Number of Processors: 1
Total Number of Cores: 8
L2 Cache: 32 MB
L3 Cache: 36 MB
Hyper-Threading Technology: Enabled
Memory: 64 GB
System Firmware Version: 2020.41.1.0.0
OS Loader Version: 582~1023
Apple ROM Info: Apple ROM Version.
Board-ID : Mac-27AD2F918AE68F61
โŒ˜ Powered by Clover revision: 5160 (master, commit 048c5bf23)
Serial Number (system): F5KZCKZXP7QM
Hardware UUID: EE6BBFD0-414C-52D7-842C-80385BC1359A
Provisioning UDID: EE6BBFD0-414C-52D7-842C-80385BC1359A
Your processor is:
My kexts running on OSX
kextstat | grep -v com.apple
Ma io ho un amd come processore
@genny if you can, try use this AppleALC at your own risk. I receive that from a friend mine, and he said that works in AMD
BACKUP YOU EFI pls!
It has been tested that the sound card cannot be driven under the macOS Sonoma system. The macOS Sequoia system has not started testing because it needs to be reinstalled. This driver seems to be fine when tested on laptops, but does not seem to work on PC desktops.
i3 Coffe Lake Sequoia.pngCaptura de Tela 2024-09-29 ร s 02.24.33.pngCaptura de Tela 2024-09-29 ร s 02.28.09.pngCaptura de Tela 2024-09-29 ร s 02.28.16.pngCaptura de Tela 2024-09-29 ร s 02.29.58.png
I have VoodooHDA installed 2 Desktops and Laptop, working great.
Today I installed in i3-9100F with Sequoia 15 / AMD RX 580 Sapphire 4 GB / OCLP 2.0.2 / Wi-Fi BRCM94360CD Fenvi
Hi @mmp369 I received this file from Discord and only think that I know that kext came from Telegram forum. But o could not tested, and for a while, Im not have been used AppleALC. Sorry for I not have more information about it. I not know this forum on GitHub
Can you provide the Telegram group number? Thanks
Sorry, two days a go I asked for the Telegram Group, but he did not answer
Are you tested?
