Regarding AMD platform sound card driver issues in macOS Sequoia(The latest version AppleAlc 1.9.3 problem has been solved)
mmp369
66
15
AMD Ryzen 3 2200G
Brand: MSI
Model: MSI MS-7B89 Desktop
CPU: AMD Ryzen 7 1700
GPU: AMD Radeon 580 Series Xunjing (Songjing) 8GB ( Separate GPU mode)
HDD: Jintek SSD 256 GB
Name: Ruiyu RTL8168/8111/8112 Gigabit Ethernet Controller/Microstar
Network card type Wired network card
Main board: MSI B450M MORTAR MAX (MS-7B89) (LPC Controller B450 chipset)
As shown in the figure below, the audio device is not displayed in Hackintool, but the sound card device exists in PCle. At first, it was suspected to be an IRQ conflict problem, but the sound card driver is normal under the macOS Sonoma system. AppleALC is just a Lilu plug-in patched for AppleHDA, but in AppleHDA is not loaded under the macOS Sequoia system, so AppleALC directly loses the Patch target, and kextstat shows that AppleALC loading has no effect.
Reactions: ccphuc
Can you provide the Telegram group number? Thanks
The name of Telegram Group the he said to me is:
Cheffkiss
Hope help you!
Cheffkiss
Hope help you!
Thank you. Can you tell the author about this? I am running the system Sequoia 15.0.1, and the desktop test still cannot drive the sound card. I plan to use the universal driver method to drive my sound card.
Reactions: Max.1974
Reactions: genny
What do you think this is?
Reactions: genny
Not if your audio works without them installed.
Reactions: genny
go~ Fix AppleAlc 1.9.2 for AMD
Thanks for sharing. I have time to test it out. I saw a new submission go~ Fix AppleAlc 1.9.3 for AMD
Fix AppleAlc 1.9.3 for AMD link download. thank. My PC ASUS X570 Pro + ALCS1220A use AppleAlc 1.9.2 not working
