Finally : Intel Bluetooth working under Sequoia 15.0 24A335
Chiracopolis
13
7
France
AMD Ryzen 7 7800X3D
Hello !
I was waiting for Sequoia 15.0 release a lot. The only issues I had with previous Betas was Bluetooth... I don't have tons of BT devices but I've got some : Apple Magic Keyboard, Apple Magic Trackpad and AirPods Pro 2. Until few minutes ago, I was not able to get bluetooth working with my Intel AX210 card : someone sent me Shaneee's kexts + the info of adding two NVRAM things and boom, Bluetooth worked! The only thing that is not working correctly tho is AirPods : sound works not that great, sometime it's buzzing, sometime it's not... Anyways, I'm very happy !
Hello !
Would you share the info for the BlueTooth 'NVRAM things' please?.
Oops wrong link!, look inside BrcmPatchRAM 2.6.9 here.
Reactions: madvinegar
Reactions: craighazan
what are the kext files i need to add my wifi caed is ax200
Here are the kexts and the NVRAM stuff needed for it to work on Sequoia
I can't get bluetooth to work. Is the inject kext needed?
I followed : https://elitemacx86.com/threads/how...macos-sequoia-and-later.2066/#google_vignette
reset NVram and all . wifi works , bluetooth not. The drivers are loaded:
kextstat | grep -i blu
Executing: /usr/bin/kmutil showloaded
No variant specified, falling back to release
   50    2 0xffffff80023f4000 0x37000    0x37000    com.apple.iokit.IOBluetoothFamily (9.0.0) 70F88B1A-2021-37F7-900F-CC042EBCADC2 <49 38 17 9 8 7 6 3 1>
   67    0 0xffffff8005cf0000 0xb000     0xb000     as.acidanthera.BlueToolFixup (2.6.9) 8D62EEA8-F50C-395B-AD95-BB79BE172568 <57 9 7 6 3 2 1>
   98    1 0xffffff8002435000 0x13ff9    0x13ff9    com.apple.driver.IOBluetoothHIDDriver (9.0.0) 0DF36FF4-47FC-3C34-BD82-F8236CD2C56E <78 50 7 6 3>
   99    1 0xffffff8001d5a000 0x6ff4     0x6ff4     com.apple.driver.AppleHSBluetoothDriver (8400.24) 5BA28DB3-0FAC-3868-911C-F6CFA27DC125 <98 78 50 8 7 6 3 1>
  120    0 0xffffff80051f8000 0xaf8000   0xaf8000   com.zxystd.IntelBluetoothFirmware (2.5.0) EA4755DF-A909-35AF-B952-6994467464F4 <38 7 6 3>
I believe AX1650 ( Dell Precision 5550 ).
Any tips are appreciated !
works on AX210, but can't pair, and I've also added NVRAM stuff. Is there anything I missed? thx
My AirPods got connected and working, but they are not nearby devices. it’s just spinning
@ openminded: believe AX1650 ( Dell Precision 5550 )
I have the exact same laptop, and I stayed on Sonoma, cause when I upgraded to Sequoia, I lose wifi&bth
My other problem is with Sleep/hibernation
Tried everything, (downgrd bios, changed acpi setup_values, dump values and map usb, boot-args..) would not work. When it works, next power on doesn't start, requiring a 10+ sec hard pow-off. Next boot says incorrect shutdown.
I can share EFI and compare (OC 1.01)
Other than that, works well with Sonoma
