Finally : Intel Bluetooth working under Sequoia 15.0 24A335
Chiracopolis
16
7
France
AMD Ryzen 9 7950X3D
Hello !
I was waiting for Sequoia 15.0 release a lot. The only issues I had with previous Betas was Bluetooth... I don't have tons of BT devices but I've got some : Apple Magic Keyboard, Apple Magic Trackpad and AirPods Pro 2. Until few minutes ago, I was not able to get bluetooth working with my Intel AX210 card : someone sent me Shaneee's kexts + the info of adding two NVRAM things and boom, Bluetooth worked! The only thing that is not working correctly tho is AirPods : sound works not that great, sometime it's buzzing, sometime it's not... Anyways, I'm very happy !
Orico 403 Bluetooh 4.0 and 5.0 508 not working, help. thank
Here are the kexts and the NVRAM stuff needed for it to work on Sequoia
Orico BTA-403 Bluetooh 4.0 and 5.0 BTA-508 not working, help me. thank
Orico BTA-403 Bluetooh 4.0 uses a CSR chip, (Cambridge Silicon Radio) not an Intel or Broadcom chip. The CSR Bluetooth chip isn’t supported in Sequoia, is my understanding.
Reactions: ccphuc
thank you for Shaneee ! my BT is finally working. Unfortunately still no Wifi on Sequoia (it worked on Ventura)
Which WiFi card are you using, Intel?
Assuming it is an Intel WiFi card, have you removed Airportitlwm.kext and replaced it with the latest release of Itlwm.kext, plus installed Heliport application? If not that would be why your Intel WiFi isn't working in macOS Sequoia. As Airportitlwm.kext doesn't work in Sequoia.
thank you for your reply Edhawk. I did as suggested, and Heliport could connect to my phone but not to my router's wifi. Turned out Heliport has a bug: it's sensitive what the SSID name is, so I just made it shorter, just one word, without spaces and special characters.
Reactions: Edhawk
@ openminded: believe AX1650 ( Dell Precision 5550 )
I have the exact same laptop, and I stayed on Sonoma, cause when I upgraded to Sequoia, I lose wifi&bth
My other problem is with Sleep/hibernation
Tried everything, (downgrd bios, changed acpi setup_values, dump values and map usb, boot-args..) would not work. When it works, next power on doesn't start, requiring a 10+ sec hard pow-off. Next boot says incorrect shutdown.
I can share EFI and compare (OC 1.01)
Other than that, works well with Sonoma
same, sonoma ok, sequioa loss I225-V,AX210,ALC8402, try different efi, no way~
my device:
rog x670e hero
7950x
ddr5 32*2
rx6600
although my hack is intel based, since upgrading to Sequoia I also had kernel panic when enabling display sleep or waking the hack in the morning from sleep.
As it turned out it's caused by process com.apple.mediaanalysisd. Since disabling it, my sleeps are rock solid. follow the link for a fix:
