Ryzen 9000
Ejh4286
86
Ryzen5950
I've added some debug statements here. Please enable logging to file Target = 67 and upload the file please.
Latest bios as of yesterday.
It's a 9950x that fails. When I swap back to the 7950x cpu, it boots perfectly fine.
I have a 7950x and an Hero, I know it works
and i am following your tries for 9950x
For this i have asked for a debug log to see inside :)
  • Haha
Reactions: etorix
Ok please test this new revision and provide same log regardless of result,
Did it boot? I don't see the error anymore? FSBFrequency was 0, causing the DivU64x64Remainder error.
I've set OC to apply a FSB of 100 if it detects 0
C++:
      if (CpuInfo->FSBFrequency == 0) {
          DEBUG ((DEBUG_ERROR, "OCAK: FSBFrequency is 0, setting default value to 100MHz\n"));
          busFreqValue    = 100000000ULL; // 100MHz in Hz
      } else {
          busFreqValue    = CpuInfo->FSBFrequency;
This can be seen in the log.
C++:
      } else {
Nope, no boot.
Last text line is the one setting bus=100
@ssuper2k system hangs always in the same place without division by zero message or do you see additional debug verbose lines?
This has more debugging added to try identify where it's hanging...
@ssuper2k Test this please. You can disable SysReport now too.. Will speed up your boot a bit.
