zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
The 'PCI Configuration Begin' error is a common one. There are multiple causes and as many fixes for this KP., See the OC Troubleshooting page linked below.
Some won't be relevant to your laptop system, others will be set as expected. Given the issues you have faced I would be careful about making too many changes at once. You would be advised to test the changes after each change.
Remember to use the ResetNvram option before booting the installer after each change to the config.
I have tried the fix of incorporating SSDT-PNLF-CFL.aml but come with following issues.
  • EFI (1).zip
    EFI (1).zip
The SSDT-PNLF.aml table in your OC setup is configured for the Backlight in an AMD system.
The Intel Coffee Lake PNLF table isn't right for your system. It contains a number of entries that won't match with the devices in your AMD system.
Screenshot 2024-09-06 at 23.11.44.png comparison of the two SSDT's.
View attachment 14952 comparison of the two SSDT's.
Got it.thank you for your help, this SSDT-PNLF-CFL.aml is from zxc2689963's configured EFI that provided for me. What else could I try? I think this EFI could pass PCI configuration(but got KP after following of USBMS identifiers non-unique with a forbidden icon. )
That’s a more expected issue with your laptop. USB errors were the main stumbling block for early access users with AMD laptops.
Hi Edhawk,
I have read this troubleshooting carefully. EC patch is included in the EFI, so missing EC patch is not possible. SSDT-HPET.aml is included in EFI, so IRQ conflict issue is not possible. I am using Crucial P3 Plus 1TB PCIe Gen4 3D NAND NVMe M.2 SSD, so it is not possible to be a SATA/NVME issue. And I also have tried disabling NVME but the issue still exist. RTC missing seems not possible on AMD 6800h's motherboard. So the remaining things I need to try is PCI allocation issues, right? Plus, do I need to upgrade my bios to the latest version(only the latest version bios is available on Lenovo site)
You also need to look at your USB port config, to see which ports are causing the duplicate port issue. You may need to temporarily disable a few ports in the kext (those you are not using during the boot/install process. So you can to get through to the installer in a consistent manner.
Thanks, how can I look at my USB port config and use kext to disable some ports?
I have tried both adding npci=0x2000/0x3000 and setting ResizeAppleGpuBars=0(my bios doesn't have Above4Gcoding option). But none seems working. I will try disabling USB port. I think I won't use two usbc port during my installation. Would you help me disable two usbc port to see whether it would work? Thank you
Post a screen image showing the Verbose text declaring the USB non-unique issue, so I can see which ports are causing the KP. Hopefully this will give us information on which ports to disable in your setup.
Although as you don't appear to have a UTBMap or USBports or USBMap kext that might be more difficult than first anticipated.
Do you have any clues on which ports should be disabled?
PRT5, the port used by the macOS installer..
This is confirmed if you look at the screenshot below and the two sections highlighted in the RED rectangles, as the non-unique identifier matches with the Cruzer identification.
Best option is to use a different port, or a USB2 pen drive, so you don't hit the USB3 port that is being duplicated incorrectly.
Just tried all 4 usb ports including usbc ports and usb2 drive. But the issue is still the same. Would you help me disable the non-unique usb port? Thank you
From my limited understanding, i think we will have to disable one XHCI controller using UMAF Tool as demonstrated here https://github.com/JamisonMurphy/Legion-5-Pro-Hackintosh
(But its risky, i dont know what all components it might disable. I tried disabling individual ports using UMAF and by mistake i disabled keyboard as keyboard is also connected through usb. Then i used external usb keyboard but it didnt detect at boot so i couldnt get into bios or boot selection menu. Then i booted into windows from there booted into advanced restart options and from there booted into boot menu options and was finally able to enable keyboard again.)
@Edhawk I think using acpi ssdt to disable the usb controller would be a better choice. But I may need some help on having ssdt to disable my usb port.
That is a possibility, but it is no more likely to work that disabling each port (individually/one at a time) in a custom UTBMap.kext or USBMap.kext. Rebooting the system to see/check which port has been disabled when the system boots to OpenCore and through to the macOS installer.
Patience would be required as this trial and error check is undertaken. Notes taken to record which port or feature was disabled as each port in the kext was checked.
But to be honest, each port should be identifiable and set with a custom 'Nickname' (shows as 'hashTag comment' in the kext's info.plist ) from when each of the ports were discovered and confirmed in Windows, using USBToolBox Tool. The output would look something like this is Hackintool > USB tab with the populated Comments field.
Screenshot 2024-09-23 at 23.18.43.png Example of USB ports with comments/Nicknames for each port so they can easily be identified.
Example from an AMD Mini PC system containing Ryzen 5 7530U & APU (laptop CPU).
