layout id
laurent
135
13
18
53
France
Amd Fx8350 Amd ryzen 7 5700x
bonjour comment connais-tu l'id de la disposition du contrôleur audio asus rogstrix b550-a
J'ai installé Sequoia Beta tout fonctionne sauf le son il ne détecte que le son HDMI de la carte graphique
MERCI
    config.plist
MERCI
Hello, how do you know the audio controller layout id asus rogstrix b550-a
I installed Sequoia Beta everything works except the sound it only detects the HDMI sound of the graphics card
Thanks
Which layout-ID were you using in previous macOS versions?
Are you using -alcbeta boot argument with the most recent AppleALC.kext?
If you are using -lilubetaall boot argument try replacing it with the individual boot arguments shown below for the main Acidanthera kexts.
-lilubeta, -vsmcbeta, -alcbeta, -wegbeta & -revbeta
Thanks
in ventura i use alc kext without argument
Not sure you are correct, as there is an entry in the DeviceProperties setting layout-id=3, see highlighted section in image below.
Capture d’écran 2024-07-03 à 20.32.32.png Is this DeviceProperties > Add entry still present in your config.plist?
View attachment 14474 Is this DeviceProperties > Add entry still present in your config.plist?
yes this entry is still present I tried the proposed arguments nothing has changed
I updated kexts
What does Hackintool > PCIe tab show as being the Device Path for your AMD Audio Codec?
This is what my Asus B550M system shows for the Audio Device.
Screenshot 2024-07-03 at 21.17.26.png AMD Audio Device highlighted
Similar but not identical Device Path to the one used in your config.plist.
Just make sure you are using the correct Device Path if you are relying on DeviceProperties to enable the Audio.
Reactions: laurent
We don't support beta versions of macOS that's why the subforums are locked. AppleALC isn't working on the majority of codecs for now it seems. VoodooHDA however works as an alternative.
Reactions: laurent
as much for me
Reactions: laurent
Yes from the Releases but you can't inject it with OpenCore,
Reactions: laurent
so I used sudo cp -R ~/Desktop/VoodooHDA.kext /Library/Extensions
and also deactivation of SIP
I have returned to macOS Sonoma and found that the macOS Sequoia system browser cannot play videos on some websites. I don’t know when AppleALC.kext will be able to drive the sound card later.
Reactions: laurent
