Ryzen 7 5700U w/ intel AX200 card - bluetooth works no wifi
captncreepy
27
Ryzen 7 5700U
Hi all,
I've replaced my Realtek card in an attempt to get wireless working but I'm not having any luck getting itlwm to run and Airportitlwm doesn't seem to work for me either. I've verified via logs that itlwm is not running and heliport does not see it.. any suggestions?
I have not, but certainly can if you think it’s worth setting up. Need to remap my usb anyhow. I’ll report back.
Is it common to have usb disconnect when sleeping? I left this mini pc on overnight - which is not normal and I received "did not eject properly" notifications for all usb ports that were occupied?
CC
That’s because your usb ports aren’t mapped correctly
Fresh usb map load (usbmap.kext & usbtoolbox.kext) and I refreshed my ACPI while there. Bluetooth is on and working fine, still no wireless - unable to turn switch on / greyed out. I also went through bios and saw nothing indicating wireless to be off and the card worked when in Windows 11.
Well, now you can eliminate it isn't a hardware which is an important step. Unfortunately we don't know why Wifi won't work and as I mentioned before I am out of ideas.
On another forum there was an Ace Magician user who had incredible problems and finally gave up and sent it back. However he mentioned a patch seems to fix Wifi, I added it to this version of your EFI. See what happens.
You sure know how to make someone's morning, I've been trying different iterations of the Airportitlwm.kext and Ventura - Windows hijacked my Sonoma... I sure haven't missed having it on a drive! Anyway, I've gotten as far as being able to turn wifi on at the titlebar but it was still locked in sys prefs. It actually first removed the exclamation when booting with the Sonoma14.5 kext, riddle me that one!
I mentioned the other card I ordered, put it in my tower today and wifi immediately came online. That gave me just enough motivation to get nowhere with hours of verbose boot screen time on this ryzen mini pc.
I'll try the patched file this afternoon, thank you very much.
CC
That normally occurs when a USB port is dropped/lost when the system sleeps/hibernates. Usually due to an imperfect USB configuration, e.g. USB port with wrong or missing connector type.
Misconfiguring USB2 physical ports with connector type (0) and Internal USB2 ports with connector type (255) is fairly common. The two port types are very different and need to be configured correctly.
Another common issue is setting the virtual USB2 ports, served from a physical USB3 port, as USB2 with connector type (0). When they should be set with the connector type that the Physical port uses, i.e. USB3 (3).
No luck, actually had trouble with OC, wouldn't boot previously working Mac drive... I'm starting to think my trouble resides in multiple eft folders. I have two SSD's a Samsung 980Pro and another Generic that came in a different windows machine. I noticed when saving a plist yesterday the name changed.. as if I opened the file from a different OC location and upon saving it reflected said location in the titlebar. Ugh!
Pics below represent the best I've gotten thus far and tho not in these pics I did have wireless referenced in the hardware report once also (accompanying the current setup).
Remapping fixed my usb eject issue, thanks. Still no headway on with wifi, wanted to ask if you think the card you posted previously in this thread is worth giving a try? I also have a bios question - my gpu is hanging and I read elsewhere increasing the dram voltage by .5 can rectify this? What are your thoughts and if you concur, where do I find that setting - I don't see it in bios (using smokeless) just frequency adjustment...
I have wifi... sort of. With no success with any m.2 cards, I've tried a usb dongle with chris111's wifi tool and now have functional wifi over ethernet - it shows up as 802.11ac NIC in network settings and has it's own controller. Encouraged to have some actual form of wifi working but it does not solve any Airplay / Airdrop or Sidecar failures. Is there a way to make this current ethernet 'wifi' useful from a continuity perspective? I'm using an Archer TU4 Plus usb unit: https://www.amazon.com/wireless-USB-WiFi-Adapter-PC/dp/B08KHV7H1S
Thanks in advance, ya'll have been great here!
CC
CC
The best place to get answers to questions like this is from the source. If you have further questions I would ask them there.
This is a small blip from Chris111's GitHub page:
Follow this Video NO-1 by @thedeadfish59​
For a fix of Apple Services (Messages, FaceTime and App Store)
  • 1- Login to your Apple Acount as Ethernet before.
  • 2- Make sur you Ethernet cable is disconnected before using the Apple Service fix
  • The only thing not working is AirDrop
  • NOTE: Testing today 2024 Feb 06 in macOS Sonoma 14.4 Beta (23E5191e) Ethernet cable must be plugin after using the Fix.
  • Discussion can be done here iMessage and FaceTime issue
  • This fix also work for ➦ Wireless-USB-OC-Big-Sur-Adapter for ➦ WirelessAdapterCloverBigSur
Alright, I have wifi!!... I think... Currently installed is an AX210 card (removed from the heatsink/PCIe adapter and not plugged in for BT power, this card - http://bit.ly/4fRlryj. I'm currently on Sequoia beta 15.0 and it shows no wifi, bluetooth, or heliport connection as you can see in the pics... However, I'm able to stream audio from Music and connect to my TV via airplay. I'm honestly not sure which kext / combo is making this work but it seems to be working well with regard to audio and video streaming, however, my network speed is locked at 90/100 mbps which is very low - normal is 1.0-1.2 gbps. The speed does not vary when I toggle my wired connection which is odd. I have added the kext for Broadcom to see if I could get any sort of connectivity - from memory - I'm sure they're not right / in the right order and will be verifying to try and figure out how I'm connected. My BT connection is showing up in Hackintool as BCM_4350C2 which I believe is the AX210 card... regardless, I added device properties for that BCM4350 instance.
Attached are my files, I welcome any insight or advice. I basically got lucky when I tried to connect to an airplay device while experimenting with these kexts in Sequoia, I had no reason to think it would actually connect.
Leesurone, I didn't see your post until coming back in to share this info, will look into this next as I still kept the adapter - thank you.
    config.plist
  • Archive.zip
    Archive.zip
  • Kexts.zip
    Kexts.zip
Heliport doesn’t run automatically when Sequoia starts, you either need to manually run the app or setup the app to run at startup, via system settings > General > Startup items. The option in the app for it to run at startup didn’t work for me.
Ok, I wondered if it should be showing something different for the icon when on... The only time it's ever seemed to run was an older version that would actually change to show wifi bars, albeit empty. That version would not perform any diagnostic reporting though. I always have to open it manually, but now I'm wondering if it's working at all. It always shows itlwm not loaded even though it is.
Do you happen to be running a wireless keyboard/mouse combo in Sequoia? My keyboard stopped working completely yet my mouse works fine (same Logitech dongle). I just chalked it up to beta but I did see a few other folks having similar issues - just not quite the same.
This worked quite well and my network speeds are back up to par, thank you much!
Reactions: leesurone
