Cannot install macOS on Ryzen 5 7600 and 6700xt
sarwar_tanvir
6
Dhaka, Bangladesh
Ryzen 5 7600
Hi there,
My Specs:
AMD Ryzen 5 7600
MSI B650M-B
Gskill 16GB DDR5 5600Mhz
Asus Dual 6700xt
I have tried many times including Dortania Opencore guide, Olarila and so on but I could not make macOS installation boot. If anyone helps me with an EFI file I would be very greatful.
Have a nice day!
You'll need NootRX.kext for a 6700 XT (look into it) and you may or may not need "agdpmod=pikera" in boot args.
No need for the agdpmod=pikera boot argument when using NootRX.kext. The fix is included in the kext.
Hi there,
My Specs:
AMD Ryzen 5 7600
MSI B650M-B
Asus Dual 6700xt
Have a nice day!
please sombody help this spec Opencore EFI file share.
AM5 iGPUs are not supported, you are going to need a dedicated AMD Compatible graphics card to be able to install. That's what system and component definitions are so important as @etorix mentioned in reply to your other post.
