Build - Asus ROG X670E Hero + AMD Ryzen 9 7950X + AMD Radeon RX VEGA 56
luchina
After a lot of work and a lot of help from @fabiosun and @Lorys89 the monster is finally ready! Thank you very much for your help!
284071152-8e319275-6d93-4de5-b651-8e473e
Component Versions
Some Notes
  • Latest BIOS 1709 or higher, DSDT patch required, developed by @Lorys89 - Pls inject this DSDT.aml and set Enable/True RebaseRegions in config.plist
  • This EFI is compatible with Intel Wireless and Bluetooth (onboard Wi-Fi 6e AX210) for macOS Ventura and Sonoma
  • USBMap (corpnewt) method
For BIOS newer or equal to v1709
DSDT Patch and RebaseRegions set to True in config.plist
https://macos86.it/topic/6542-bug-fix-for-am5-new-firmware-motherboards-dsdt-fix/
Benchmarks
- Speedometer v2.1
- Geekbench v5 & v6
https://browser.geekbench.com/v6/cpu/3609806
https://browser.geekbench.com/v5/cpu/21961976
- Dehancer Benchmark / Davinci
- CPU Endurance for 10 minutes
- Cinebench R23
- Cinebench 2024 (CPU & GPU)
- Blackmagic RAW Speed Test
- Blackmagic Disk Speed Test
- Amorphous Memory Speed Test
luchina
Copy/Download of EFI
- Attached to this post
Important
- EFI without kexts for Wireless because of the file size limit here on the forum;
  • EFI-OC096-ASUS-ROG-CROSSHAIR-X670E-HERO-AMD-RYZEN-9-7950X-RADEON-VEGA-56.zip
PrichA
Hey,
Thank you for this. I have a slightly different motherboard and graphics card. Any advice on whether I can still use this EFI or tweaks I can make?
Motherboard: Asus Rog Strix x670e F Gaming Wifi.
Graphics Card: Radeon Rx 580x.
Thank you in advance.
luchina
Hey,
They are different cards, ideally you should create a new EFI for your hardware.
I suggest using the BIOS "ROG STRIX X670E-F GAMING WIFI BIOS 1602" and then creating the EFI.
If you want, update your BIOS to the version mentioned above, after updating, set "Exit > Load Optimized Defaults = YES", enter Windows and use acpidump to extract the ACPI tables and send them here so I can help you.
PrichA
ok will give it a try. I'm on bios 1709. Will that work or do i have to roll back?
www
Is it works fine with X670E HERO BIOS 1807?
