zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
Enable the SSDT-XOSI.aml table from your /EFI/OC/ACPI folder in your config.plist. The SSDT is currently set to Enabled = False but the companion ACPI patch in your config is enabled.
Or disable the companion ACPI patch required for the SSDT-XOSI.aml table in your config.plist, as without both parts being enabled the _OSI to XOSI ACPI patch and table won't work.
Looks like you also need to enable the SSDT-XOSI
What spec does your Legion 7 Slim contain, i.e. CPU, RAM, GPU, WiFi etc.
Provide a copy of your system DSDT.aml.
You can extract the DSDT.aml in windows using Corpnewt's SSDTTime python script. I am assuming you have access to a drive containing Windows 11 that works on this laptop.
Try this revised EFI, based on the EFI provided by @Middleman.
I have edited the EFI's subfolder contents and the config.plist.
See if this gets you any further along the boot process.
No, I don't have windows in my laptop. I changed a new SSD in my laptop. But my friends has a similar one (https://www.lenovo.com/us/en/p/lapt...on-slim-7-gen-8-(16-inch-amd)/len101g0029?org) with windows installed. Could I try to extract it from my friend's one?
Just tried your revised EFI, and it ends up with this error. And next I will try to use the extracted DSDT.aml to see what is going on
Is it the same model of notebook, the version of bios that I have never seen before
Would Provide a copy of your system DSDT.aml?
macOS can't find CPUs. Delete any SSDT-CPUR/SSDT-PLUG/SSDT-PLUG-ALT and make a PluginType SSDT in SSDTTime.
If the DSDT.aml isn’t from your laptop it is not going to tell us what we need to know.
Even different versions of bios for the same (identical) laptop will produce a different DSDT.aml.
So obtaining the DSDT.aml from your friends similar but not identical laptop is not going to cut it.
Reactions: redhorse1990
Ok, I will dump one of my laptop from ubuntu disk.
Reactions: Edhawk
This is the DSDT.aml file that is dumped from my own laptop in Ubuntu flash disk.
Thank you so much for helping me configuring my EFI.
OK, I have had a look at your DSDT.aml.
Using Corpnewt's SSDTTime and your system DSDT.aml I have generated a number of SSDT's and ACPI patches for your system.
Screenshot 2023-09-02 at 21.28.57.png SSDT's and ACPI patches generated from your DSDT.aml
These are contained in the Results folder attached below.
These SSDT's and patches have been added to the /EF/OC/ACPI folder and config.plist, which will hopefully help you boot macOS on your system.
Give the EFI-3 folder below a try, just remember to rename it to EFI before you use it.
Also make sure you use the ResetNvramEntry.efi before you boot your system with this revised EFI folder.
  • When you get to the OC boot screen, press the Spacebar,
  • This will unhide a number of drivers and tools. ResetNvramEntry.efi will be among them.
  • Highlight the driver and press enter key, or select it with your mouse.
  • Using this driver will clear any old Nvram entries, so you are booting with the entries in the new EFI and config.plist, not the old entries etc.
View attachment 11769 SSDT's and ACPI patches generated from your DSDT.aml
First, I would like to thank for your help. I entered the Reset Nvram key before I boot. After restarting, it still gets the following error message. Would you help me take a look again? Thank you
Which NVME drive are you using?
If I recall correctly, some AMD laptops come fitted with unsupported NVME drives, i.e. the controller used on the drive isn't macOS compatible.
The only way to fix this is to replace the NVME drive with a supported drive, Western Digital SN570, SN770 or similar work fine in macOS.
My NVME drive is​
Crucial P3 Plus 1TB PCIe Gen4 3D NAND NVMe M.2 SSD,​
I have successfully used a similar Crucial NVMe to build a MacOS with (https://www.msi.com/Motherboard/B450I-GAMING-PLUS-AC/support)
