zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
Also, my efi has three yards removed, so you need to add them yourself
Hello, I have a laptop with the same configuration, and I also encountered this problem with your EFI, did you install it through "com.apple.recovery.boot", I tried to disable XHC1, it can enter the installation interface, but cannot use any network
What's your BIOS version?
First of all, thank you for sharing, I tried the EFI you shared, only modify the CPU core patch for 5800H, and start -v debug mode, under the two versions of BIOS of G9CN33WW and G9EC32WW, pass "com.apple.recovery.boot "Recovery installation, but it cannot start normally and enter the installation interface, and the same error as above appears.
That being the case check your bios to see if you have 'Above 4G Decoding' enabled. As you don't need both the npc boot arg and this option enabled in your Bios.
You need to check which of the other possible issues that can be causing this kernel panic is relevant to your setup.
# PCI Configuration Begin
My bios version is KFCN27WW, and I don't see Above 4G Decoding options in my bios. Thank you
Do you have above 4G decoding in your bios option? Actually, I don't have this option in my bios
Then you need to add the npci=0x3000 boot argument to your config.plist.
This is @ExtremeXT config with added SSDT-NVME-DISABLE.aml that disable first default nvme slot and new XCH1 fix. Thats working for me now.
UPD. This is for 5600h version so change core count in config.plist if you have 5800h
Reactions: kalkmann
My graphic card is 6600S. I think 6600S and 6600M has same kind of GPU cores. Do you scussesfully installed MacOS on your computer?
@redhorse1990
If your DGPU is a AMD 6600S then you could perhaps try this - add agdpmod=pikera onto your existing NVRAM boot-arg (to enable it). Also make sure that you have Lilu, VirtualSMC & Whatevergreen.kext enabled and that NootedRed.kext is disabled (if it is present).
@redhorse1990
I have tried your modification. But still have no luck to work.
Okay @redhorse1990,
I had another look at your build. Turns out you missed a number of ACPIs in the EFI including EC-USBX-LAPTOP, SSDT-ALS0, SBUS-MCHC & SSDT-PLUG-DRTNIA
which are essential for an AMD setup so I have added those in for you. I saw your ResizeAppleGPUBars setting was incorrect so I have changed that to -1 instead of 10.
However I have disabled a handful of kexts and SSDTs such as AMDTscSync, SSDT-IGPU-DISABLE and SSDT-XOSI. Also for the WiFi you should not enable BOTH Airportitlwm AND itlwm - it is one or the other. For simplicity I have disabled them both. I have also added (but not enabled) NootedRed for convenience, added & enabled NVMEFix and also added and enabled USBInjectAll for testing purposes. As we are using USBInjectAll I have disabled your custom UTBMap & USBToolBox (since only one set of kext is needed). Please note USBToolbox.kext is actually no longer required as of latest OC 0.9.4. so if you want to revert to it, you only need to enable UTBMap.kext (and disable USBInjectAll).
As for everything else, SecureBootMode has been set to Default and I have unchecked Booter > SetupVirtualMap as that's not needed.
I have also added in extra settings for the Device Properties for the RX6600S. If everything goes as planned, it should boot macOS with the RX6600S.
Okay @redhorse1990,
Hi, I have tried your modified EFI. However I got the following error in my boot to installation.
Would you kindly provide me some help?
Thank you
