[Testing] Intel WiFi itlwm driver for Sonoma
joostiphone
47
35
18
github.com
i7-9700k
Hi all, and @CaseySJ
I think it's pretty easy for you gents, but I want to understand how I can activate this test kext driver in my EFI, to play around with in my test setup for Sonoma. Can you please check my EFI?
The driver to test with can be found here (or attached):
My current Sonoma test EFI is attached:
I think it would be great to keep using the Bluetooth of the Fenvi card, combined with the Intel WiFi.
Do I need to make changes to 'SSDT-UIAC-DESIGNARE-Z390-FD-DEFINE-R6-USB2-ON-TB-V3-withFenviBluetooth.aml'?
You may not have seen this post on TonyMac as it's in the Z490 Vision D thread...
...but it contains the solution to your problem:
I indeed didn't see that one. Thanks @CaseySJ ! That was it. The WiFi works pretty decent indeed. AirDrop etc. isn't working, but perhaps that will change with the further development of the kext.
I also booted with this efi (so with Airportitlwm-Sonoma enabled) in Ventura, and funny enough the WiFi is also working in Ventura. Or does Ventura switch to Fenvi WiFi even though the SSDT is disabled? If so, what does that SSDT do?
I guess CNVW is the name of the wifi-bt module on the mobo (I had no clue).
Reactions: CaseySJ
AirportItlwm-Sonoma-Preview05 just came through on Github.
Caution:
This is only meant for Sonoma beta 5 (and possibly higher), and not for Sonoma beta 4 and lower. This is important because if you will use AirPortItlwm-P05 on Sonoma beta 4 or lower it will cause a kernel panic. This has something to do with Apple changing API interfaces within Sonoma starting with beta 5.
Caution:
https://github.com/OpenIntelWireless/itlwm/releases/tag/v2.3.0-alpha.
I saw that, but i already have the ethernet and that is enough for me and above all no trouble
Reactions: Edhawk
Which is fine, but we're in the itlwm topic, so we're talking wireless here icw the airport kext. Version 2.3.0 alpha is also not for Sonoma.
Soory i clicked on the link in my topic, and found me here. but that's nice to see work on progresss for Sonoma
Reactions: joostiphone
@joostiphone I downloaded Preview02 of the Sonoma Kext as I'm on a earlier Public Beta of Sonoma. I just added the kext to my EFI, rebooted and I now have WiFI. Happy Days!.
