zxc2689963
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
  • EFI-2023-10-5.zip
Solution
Panic from Monterey 12.6
CNGZ2022
6800和5800CPU内核应该是同一代吧,主要区别在GPU,我把igpu关了,CPU数据应该不需要修改太多吧,我不是太清楚
有一个核心参数要修改;内核里的_cpuid_set_info要修改为对应的cpu参数才行;5800对应的是B8080000 0000
翻斗花园-胡图图
大家好,我已经解决了5800h的efi,现在蓝牙也可以正常使用了。这是我的efi,请自行更改序列号和其他数据View attachment 11605
您好,我的笔记本电脑型号和你的一样,操作系统版本在13.4.1,直接应用你的EFI在启动界面启用XCH1白苹果进度条无法加载
Can we keep it in English please. Even if using a translator.
Thanks
CNGZ2022
Make sure the cpu and graphics card are the same as mine. I've also encountered the progress bar and once or twice at first, the restart never happened
Do you have npci=0x3000 boot argument in your config.plist?
If not try adding it as that boot arg usually fixes ‘PCI Configuration Begin’ errors.
redhorse1990
No, there is no npci=0x3000 boot argument in my config.plist. I have tried adding npci=0x3000 in my boot arg, but get the following error.
Here is my EFI.
Thanks for helping
with npci=0x3000 stuck on same place
That being the case check your bios to see if you have 'Above 4G Decoding' enabled. As you don't need both the npc boot arg and this option enabled in your Bios.
You need to check which of the other possible issues that can be causing this kernel panic is relevant to your setup.
# PCI Configuration Begin
kalkmann
