ASUS Vivobook AMD Ryzen 7 5800H Can I install monterey?
Jo-Toku
Not until the IGPU compatibility is solved. at this stage Ryzen 5000 series is not working last time I checked
It works since 2 days ago.
Jo-Toku
Would it work with Mojave?
Yes, Big Sur or older versions of macOS should be fine, as the older drivers are not affected.
Just now, My Ryzen 5 5600g iGPU work on Monterey with new nootedred.kext, work fine, no GVA support yet.
Your laptop will be using basic drivers (VESA mode), i.e. the drivers Apple Systems fall back to when they have a graphics issue.
You will not have metal support or graphics acceleration in macOS Monterey or Ventura with NootedRed.kext.
shuhung
Metal work fine on Montery, com.apple.webkit.gpu work good on Safari and DuckDuckGo browser. my 2200g work better than 5600g, so far no hang on Chrome (HW acceleration disabled), GVA not work yet but 2560x1440 @ 60 fps VP9 video playblack good and CPU utilization is low.
