New EFI: B650E/R9 7950x3d unable to get MMIO in OC Debug Logs
zgamer109
24
7
Ryzen 9 7950X3D
Hello,
I am trying to create a new config for my setup:
Primary AMD Build: Ryzen 9 7950 X3D-32GB DDR 5 16x2-2 NVME SSDS: Samsung 970 Pro - MacOS, WD Black 1TB Windows 11-1TB WD Black Storage HDD
Asus ROG B650E - F Gaming WIFI-FenviT919 - Wifi/BT- Asus TUF RX 6800 XT 16GB- Deepcool C510 Mesh Digital Case -Segotop 850W PSU
Im following the guide and I have switched to the OC 0.9.1 Debug Version in addition to enabling devirtualize mimi along with setting the additional debug settings in my config so it saves a log file.
The problem is im trying to find in he log the: MMIO devirt start so I can whitelist it but there is nothing in the log.
Any suggestions on what I should try, is there any settings in the bios that should be adjusted?
Im using a config I previously created but does not boot not sure if I should try the efi following the guide here and try that?
Thanks for any assistance.
This is solved. I had to select MacOS in the picker and then I was able to find it in the logs file
I’ll follow-up on this soon. Saw the files that were posted in the Asus X670E Gene thread.
Incidentally, does your BIOS have an option to disable the 3D Cache?
Please try this config.plist
Im going to check, Im pretty sure it does, and I just disabled the ipgu as well as I don't need or care about that.
Cannot seem to find anything in the Bios to adjust the 3D Cache. Also checked im on the latest Bios from Asus 1222.
The boot log shows an error loading the SSDT that creates EC device. System will not boot unless we fix that error.
I’ll check your SSDT soon.
@zgamer109,
Please make the changes shown in screenshot below, then reboot. When the OpenCore boot picker appears, a new SysReport folder should be created in the EFI partition. Please compress (zip) and post that folder.
Reactions: zgamer109
He has b650e-f and I have b650e-i
If you want you can try my efi
@zgamer109,
I went ahead and did that but before I did, I mapped my ports using usb toolbox and replaced the kext as well. I put everything into the zip file.
@zgamer109,
As suspected, there is no \_SB.PCI0.SBRG.EC0 device in your DSDT. So please replace SSDT-EC-AMD.aml in your EFI/OC/ACPI folder with attached version and reboot. Let's see if this one helps.
My efi could boot, only I made a distraction error in kernel patches, I'll pass you other efi
@zgamer109,
1 of 2 different things happens either scenario no boot, if I replace the ssd and clean snapshot I get a message about a duplicate airport kext, if I disable it I stop at 1 error if I leave it as it is it stops at a different error. Let me know if you need me to upload anything else.
Reactions: Lorys89
Looks like there are 2 different versions of AirportItlwm being loaded.
Im trying to compare in between working but the efi from @Lorys89 seems to be booting and everything is up and running. Got to test a little more.
Reactions: Lorys89
In my efi sure will be added ports to the map usb kext, since the version itx has fewer ports, and then set as internal the third nvme if you mount it, for other I think everything works
Reactions: amdeez
