zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
I didn't find any solution and focused on making EFI as compatible as possible, reducing the number of boot failures. So far so good, I can live with up to 5 forced restarts to enter the system with everything working.
So I went to try to make Sleep/Wake work. The system is going into sleep (machine turns off and the power LED is blinking, normal).
But when waking up, the date is usually 1 month ahead, time is also wrong and the system becomes unusable.
Can anyone point me to solutions for sleep/wake issues on an AMD platform?
Could you make your USB work?
As mentioned, I haven't found a solution.
But, as already reported by other users, if you don't use the GenericUSBXHCI kext, the system successfully boots (with all USB ports working) randomly.
With luck, no more than 5 consecutive attempts. Sometimes I have several consecutive success boots with Ventura. But there is no rule.
Trying to make sleep work so I don't have to do daily reboots, but it seems that there is something with the RTC of this notebook that is not compatible...
Did you install from USB? I tried use USB flash to install. But it died out on entering installations. It went problematic when the bios tried to hand in the usb control to the flash.
My journey to Ventura:
I understand your question. If you're referring my trying in Proxmox, I abandoned that idea and went with "native" installs.
- I started with a Big Sur 11.2.3 USB stick using MacPro7,1 EFI (from the first post). I disabled all kexts or ssdts related to USB. On this machine, if you keep resetting when the boot hangs, one time you are lucky and it passes until the system starts (the installation or the installed system).
I think everyone is using GenericUSBXHCI.kext precisely because of this problem of the hang on boot, with something related to USB controllers.
After Big Sur was installed, using the wired network, I downloaded the Monterey installation and installed it on a new APFS volume. From Monterey, I did the same for Ventura, with the particularity of using a pendrive to start Ventura with this EFI (MacBookPro15,2) and the other 2 use the EFI that is in the NVME itself (MacPro7,1).
I have Windows and the 3 MacOS only for testing USB...
Hello, my GitHub repo has received a number of updates including a new workaround to the USB issue, with SSDT-XHC0-DISABLE, we are disabling the XHC0 controller which houses: the internal camera, the USB port on the left and the USB-C port. Disabling this controller results in a perfect boot with the other USB ports fully working.
In mine, it kept freezing when loading the kext USBToolBox (XHC1: waitingForMatchingService), both in Monterey and in Ventura.
On my model (variant with the 5600H), the notebook's keyboard is also on the XHC0.
Thank you! Happy to know that there are more people insisting on a solution!!
Reactions: MinhHoangg
Keyboard being USB connected is impossible, it's PS/2. I'm not sure why it doesn't work for you, perhaps try disabling UTB? -utboff boot arg. Or try unplugging all USB devices when it gets stuck.
With the -ubtoff argument it freezes at the same point as always.
About the keyboard, I don't understand either, when it works is precisely by loading the kext voodoops2, but I had already tested disabling port by port in the BIOS advanced options (using a Patch via pendrive to enable these advanced options). When I disabled the HS04 (ITE Device) the keyboard didn't work and I had to connect an external one. In these advanced BIOS options there is also no way to completely disable a controller, it does not let you disable any USB-C port (each controller has 2 of these).
ITE is an embedded device which controls onboard components, it's not the keyboard.
Reactions: kalkmann
Yes, I think the RGB, right? But anyway, it doesn't work here if I disable XHC0 or the specific port.
Hopefully mine is an isolated case.
Can you send your DSDT?
Reactions: ExtremeXT
Same case for me
This is the port that if I disable it via advanced bios (penboot patch - Counting from port 0, equivalent to HS4 with the ITE device mentioned in print above), it kills the keyboard and I have to connect an external keyboard.
my bios doesn't have the advanced option to disable a USB port
Our models have a different USB configuration. Using the UMAF tool, I disabled the XHC1 and problem solved.
As a result, I was left without USB-A on the right, USB-C on the left, and internal bluetooth (Intel AX-210).
The rear 3 USB-A ports and 1 USB-C port, keyboard and camera are working.
You have the Legion 7 slim?
Reactions: Jo-Toku
