Asus BIOS Upgrade - Stuck [EB|#LOG:EXITBS:START]
sandflea
I recently upgrade my Asus ROG Strix X570-I to the latest BIOS 2407. After that, OpenCore gets stuck at [EB|#LOG:EXITBS:START]. It was booting fine with the original BIOS 1407.
I had to change these two configurations in the OC:
  • RebuildAppleMemoryMap = True
  • SetupVirtualMap = False;
Just wanted to share this info because I spent half a day trying revert back the BIOS and trying out all different configurations...
Per Aluveitie's note below, I check and found that I also had:
  • SyncRuntimePermissions = True​
Thanks for sharing, though I have the ASRock ITX I also got a BIOS update with the latest AGESA so this is good to know 👍
Buki
Thanks for sharing. Thought I lost ryzentosh!
Strange. I updated my MSI BIOS to include the Updated AMD AGESA ComboAm4v2PI 1.0.0.2 patch. No changes were needed to my config.
I already had the settings as described, but for the new BIOS I had to also enable SyncRuntimePermissions otherwise macOS would not boot anymore.
DeepTrik
Thank you @sandflea! this helped me get my system back up and running! I was so panicked!!
sandflea
I had SyncRuntimePermissions enabled as well.
yuning_ok
I had these three sets to be trues, but still can not boot to mac
biller30
Thank you so much for the tip, you save my whole work after update the bios for MSI Gaming Plus x570.
basso
Hello everyone I tried booting macOS on my Asus X470-F but it was impossible, I tried every combo of RebuildAppleMemoryMap, SetupVirtualMap, SyncRuntimePermissions and going down in bios version but failed.
In a final attempt before going to the shop and drowning my sorrows in cognac I took a chance and upgraded to Version 5806 Beta / AGESA V2 PI 1.1.8.0
  • RebuildAppleMemoryMap:true
  • SetupVirtualMap:false
  • SyncRuntimePermissions:true
AND IT BOOTED!
I think getting bios up to AGESA V2 PI 1.1.8.0 was the fix.
