Urgent! Help! Can't boot Monterey from Local Mac Disk!
hzxyb
19
Hi, EveryBody, I reinstall my pc but I can't boot from my local disk. I've set the EFI file to local EFI Partion, the EFI file are same as the USB installer. I need help to solve this issue. thanks!
PS: the attach is my EFI files.
I have an other question: my Mac OS disk no# is disk1s1s1, but when I use EFI mounter to mount the EFI Partion, it's disk0s1?
plug the usb installer boot options:
unplug the usb installer boot options: I don't know why there have a windows boot manager, because I don't have windows system devices.
Below is my PC info:
disklist:
EFI Partion File List:
BIOS setting:
Just change the CSM disenable, secure boot value to "other OS"
disklist:
BIOS setting:
I had the same issue with dual boot when I upgraded opencore. Remove the Microsoft folder from your efi, boot into opencore and then Mac OS again, then put the microsoft folder back into your EFI. Then you can go back into bios and choose opencore. That will fix the issue.
I removed the Microsoft folder in this version of your EFI for you.... to show you what I mean. You still need to do it on the EFI on your drive, because the motherboard needs to see past the Windows EFI folder to get to opencore on the drive. DO NOT DELETE THE MICROSOFT FOLDER, YOU WILL NEED TO PUT IT BACK TO BOOT UP WINDOWS AFTERWARDS. JUST MOVE IT TO YOUR DESKTOP TEMPORARILY
Reactions: hzxyb
Hello OG Nerd, thanks for you help. the issue is solved now. thank you very much!!!!
Reactions: OG Nerd
