Hello how i can install mac os 10.13 high sierra on my old year 14 computer? no efi
Renatosxradeon2004
Hello i have my computer old years 14 her not have efi how i can install mac os high sierra i am new i have files
  • gibMacOS-master (1).zip
  • Clover_v2.5k_r5070.zip
  • TransMac-14.6.rar
What is the specification of your laptop?
Have you edited the AMD Kernel patches in the config.plist, so they will work with your Dual-Core CPU?
Have you created the Clover bootloader in Legacy Bios mode?
Which discrete graphics card are you using in your AMD system?
Which motherboard are you using?
No support for K8 CPUs.
True, they usually require a patched kernel to boot macOS. They don't usually work with the AMD Vanilla method.
