impossible to turn off the computer restarts each time if not everything works perfectly
laurent
132
13
18
52
France
Amd Fx8350 Amd ryzen 7 5700x
bonjour apres avoir fait le tuto de la mise a jour de securite 2019 005 shanee tout fonctionne parfaitement sauf l'arret repart en boucle
Merci pour ton aide
highsierra 10.13.6
AMD fx 8350
gigaoctet GA-9701-DSP3
ssd 240gb
ram corsaire 4gb x2
MSi GeForce GT 710 2048 Mo
Reactions: OG Nerd
Have a look at my success story regarding the FX8350 system.
Hello, thank you for your answer
i used your efi and i installed catalina i still have the problem
the computer restarts fine but does not shut down
I don't have the same motherboard as you but everything seems to work
gigabyte 970a-ds3p fx8350
and the audio codec does not work it is not an alc
hello i used your efi file to install big sur 11.6.1 on my gigabyte 970a-ds3p motherboard amdfx8350 and it works very well
except audio
I used the voodookext
but it is not charging
invalid parameter
would you be kind enough to help me thank you
miracle I managed to modify the config plist and make the audio work
hello it's me again. the problem is that i don't know how to compile the patches i downloaded maciASL moreover i also don't know how to change the audio codec
I managed to modify the plist configuration for the ethernet codec
but it's not obvious, wouldn't there be a tutorial explaining the compilation?
Thanks
hello I can't find XHC in the DSDT as indicated in the hack
Your DSDT.ml may not contain an XHC device.
It is an old system. So it may use a different names for the USB controllers. You are also likely to have a system with multiple USB controllers.
For example my Asus Sabertooth FX990 R2.0 has 3 xASMedia USB controllers, 3 x EHCI USB controllers, 3 x OCHI0 USB controllers and 1 x OCHI2 USB controller.
The ASMedia controllers work Out of the Box (OOB) at USB3 and USB2 speed (5 Gb/s & 480 Mb/s)
The EHCI and OCHIx controllers only work at USB1.1 speed (12 Mb/s), which is fine for mouse, keyboard or Webcam. But rubbish for anything requiring faster connection.
Because of this I have installed a USB PCIe card that provides 5 x external USB3 ports and a 19-pin case front connector. This card uses a Fresco Logic USB controller (FL1100), which works out of the box in macOS.
Have a look in Hackintool > PCIE devices tab to see which USB controllers are present in your system.
A copy of the pcidevices.txt from my Sabertooth system is attached below, with the USB controllers highlighted.
Your motherboard is of a similar age so will probably use similar USB controllers.
