After one week I finally made my own EFI ready and successfully boot into macOS.
However, I found my USB wireless card (Comfast 811AC which should absolutely run in macOS) cannot be found, but other USB devices like my mouse, keyboard and USB drive works well.
And there is another problem. When I power off in mac, display turns off but the motherboard is still running. After shutting the power to reboot, BIOS cannot display, with a red LED on the motherboard on. Only after cutting down the power supply for a while would the BIOS turn on normally.
I would be more than appreciated if you would give me a hand.
My hardware list:
Processor: AMD Ryzen 9 3950X 16-Core
Motherboard: Asus Pro WS X570-ACE (AMD PCI Standard host CPU Bridge)
Graphics: AMD Radeon RX 5700 XT (8 GB/Sapphire)
Memory: 64 GB (KLEVV DDR4 3200MHz)
Disk: WDC WDS100T2B0C-00PXH0 (1 TB/SSD) *2 (one for windows, another for mac)
Sound card Realtek @AMD High Definition Audio Controller (Sound is OK with my monitor audio via DP)
Intel I211 Gigabit Network Connection/Asus (RTL8117)
Here is my Drivers and Kexts list:
Kexts:
AppleALC.kext
AppleMCEReporterDisabler.kext
Lilu.kext
NVMeFix.kext
VirtualSMC.kext
WhateverGreen.kext
Drivers:
ApfsDriverLoader.efi
HFSPlus.efi
NvmExpressDxe.efi
OpenRuntime.efi
My hardware list:
Kexts:
AppleALC.kext
Lilu.kext
NVMeFix.kext
VirtualSMC.kext
WhateverGreen.kext
Drivers:
HFSPlus.efi
NvmExpressDxe.efi
OpenRuntime.efi
