Here's the build and the EFI I am working with: https://github.com/radianttap/EFI-Asus-ROG-Strix-B550-I
Hardware is all OK, I have Windows 10 installed and works with no issues.
BIOS is latest, 2803.
AMD RX6800 reference should be working out of the box.
I am trying with Monterey 12.6 installer. It boots up fine, shows language picker and then switches to grey screen and stays there, nothing happens.
Tried various things I could find online including:
Currently EFI has most .kexts disabled, the stuff that are needed are enabled.
Next I may look into SSDTs but I am not using anything strange, I think.
Any ideas are welcome.
- NVMefix kext, makes no difference
-radvesaboot arg (which gave me black screen and no language picker)- nvram reset (there were mentions of this being issues in betas so tried it anyway, no difference)
