Yes I think so. Have you tried to use the ResetNVRAM function and rebooted the system?Ok seems odd but it seems that this problem only occurs when I reboot my pc. If I shut down my pc and then boot it, this message doesn’t occur… Is it possible that there are still settings from opencore in the nvram that could trigger this?
Hi everyone. Built-in bluetooth and wifi works successfully on my asus e-gaming with Monterey 12.4.
Just add four kexts to your efi folder.
you're right. works with three kexts.You shouldn't need the BcrmPatchRam3.kext as that is specifically for a Broadcom Bluetooth module.
Nice work,Hi everyone. Built-in bluetooth and wifi (Intel® Wi-Fi 6 AX200) works successfully on my asus e-gaming with Monterey 12.4.
Just add three kexts to your efi folder.
Supported PHY Modes: 802.11 a/b/g/n/ac
On specifications of motherboard onboard BT 5.0
I don't use airdrop. WiFi about 250-300 mbps (with my router). Magicmouse works fine.Nice work,
I was just wondering how the speeds are? Do any to Apples services like AirDrop work?
could you test airdrop and handoff pls? my EFI using the fenvi T919 for wifi and the ASUS BT-400 USB dongle is super stable.. but I would prefer to use the onboard BT and wifi if possible instead , but handoff is super important to me so I don't want to give that up.I don't use airdrop. WiFi about 250-300 mbps (with my router). Magicmouse works fine.
Unfortunately, I could not connect via handoff or airdrop to my macbook pro, although using the same apple IDcould you test airdrop and handoff pls? my EFI using the fenvi T919 for wifi and the ASUS BT-400 USB dongle is super stable.. but I would prefer to use the onboard BT and wifi if possible instead , but handoff is super important to me so I don't want to give that up.
