Forward: This thread is specific to my own EFI for the Asus X570 I Gaming. The EFI should work on most Asus X570 & B550 motherboards.
The EFIs provided are the latest release (unless otherwise noted), feature rich, robust and are stable on my system prior to posting. The EFIs include support for Linux, CPU temperature, GPU temperature and fan speeds in third party apps like iStat Menus. The EFIs provided are drag and drop ready for the most part, only needing the Core Count and Platform Info to be set.
Some EFIs may not include necessary Kext and provisions for all the features to work on other Asus X570 & B550 motherboards such as:
Feel free to modify and change EFIs to suit your own needs.
If you are looking for a basic barebones EFI template I would suggest going to AudioGod's ASUS ROG STRIX X570-E GAMING - Big Sur & Monterey Beta - OpenCore 0.7.4 EFI an which is an incredible resource and was how I got started with a Hackintosh.
Operating System:
I am grateful to AudioGod, Shaneee & Aluveitie for their incredible contributions.
In the spirit of the aforementioned individuals I will do my best to answer any questions within my knowledge scope when time permits.
Operating System:
- MacOS Ventura (13 beta) & Monterey (12.5 beta 2)
- Windows 11 (Insider Developer)
- Holo SteamOS
- Motherboard: Asus X570 I Gaming
- CPU: AMD 5950x
- GPU: Sapphire Nitro+ 6800 XT
- RAM: Crucial Bastic 64GB 3600MHz CL-16
- NVMe: Western Digital SN850 2TB NVMe: Western Digital SN550 2TB SSD: Western Digital S500 2TB & Western Digital S500 500GB
- Case: FormD T1
- PSU: Corsair SF750
- WIFI: BCM94360NG M.2
- Cables: PSlate Cables & J-Hack M2426
- Custom Closed Loop: Nouvolo Aquanaut Extreme, EK DDC 4.2 Pump, EK Quantum Vector & (2) XSPC TX240 Radiator
