The quote above shows your USBMap.kex was activating 10 USB ports.Your USBMap.kext is activating 10 ports, as follows:
OHC1
OHC2
- PRT1 - USB2
- PRT2 - USB2
- PRT3, PRT4 and PRT5 are disabled
OHC4
- PRT1 - USB2
- PRT2 - USB2
- PRT3 - USB2
- PRT4 - USB2
XHC0
- PRT1, PRT2, PRT3, PRT4, PRT5, PRT6, PRT7, PRT8 and PRT9 all disabled
- PR10, PR11, PR12, PR13 and PR14 all disabled
- HS01 - USB3
- HS02 - USB3
- SS01 - USB3
- SS02 - USB3
nope... still cannot detect USB2.0 port, only USB1.1The quote above shows your USBMap.kex was activating 10 USB ports.
Looking at the USB ports on your motherboard this is the correct number of ports for your system.
However, what is not correct is the motherboard USB2 header ports connector type.
Your motherboard has 2 x USB2 header ports, which support a maximum of 4 USB2 ports.
- Those are set as USB2 (0).
- They should be set as Internal (255).
I have edited your USBMap.kext to reflect the above thoughts, i.e. changed the OHC2 ports to Internal - 255.
- From the above It think that means the 4 x ports served by the OHC2 controller are most likely to be the Internal header ports.
- There are only 2 x physical USB2 ports which looks like they are served by OHC1.
- The 2 x physical USB3 ports are served by XHC0.
Try using the kext attached below and see if it makes any difference.
You do have USBToolBox.kekt in your Kext folder as well as the generated USBMap.kekt?nope... still cannot detect USB2.0 port, only USB1.1
yes, i have the USBToolBox.kext and i tried both enabling and disabling the kext in config.plist and it still didn't do any improvement to the USB speed. BTW i think USBToolBox work with UTBMap and not the USBMap, because UTBMap and USBMap come from different dev, and i think USBMap could work without USBToolBox.kext because it didn't have any reference in info.plist, on UTBMap however, there's a reference to USBToolBox inside the info.plist..You do have USBToolBox.kekt in your Kext folder as well as the generated USBMap.kekt?
The generated file will have no effect without USBToolBox.kekt.
You are correct: I meant UTBMap.kext.yes, i have the USBToolBox.kext and i tried both enabling and disabling the kext in config.plist and it still didn't do any improvement to the USB speed. BTW i think USBToolBox work with UTBMap and not the USBMap, because UTBMap and USBMap come from different dev, and i think USBMap could work without USBToolBox.kext because it didn't have any reference in info.plist, on UTBMap however, there's a reference to USBToolBox inside the info.plist..
