OpenCore 0.8.0 EFI Update , 18th April 2022.
Changes made include,
Note 2 - If you are using a 6 or Less Core Ryzen then go into the Config,plist and under PlatformInfo->Generic Change the ProcessorType from 0 to 1537, This will list your CPU info correctly inside About This Mac.
Note 3 - The SmallTreeIntel82576.kext is now fully working as of Monterey 12.0 Beta 8
Note 4 - BIOS SETTING CHANGE - Since Bios Revision 4010 Power On By PCIe can break shut down on some peoples builds so ensure the following setting is now set as disabled.
IMPORTANT PATCH INFO TO SET THE CORRECT CORE COUNT FOR YOUR CPU
Core Count patch needs to be modified to boot your system. Find the two algrey - Force cpuid_cores_per_package patches and alter the Replace value only.
Changing BA000000 0000/BA000000 0090* to BA <CoreCount> 0000 0000/BA <CoreCount> 0000 0090* substituting <CoreCount> with the hexadeciamal value matching your physical core count.
So for example a 6 Core 5600X would result in these replace values, BA 06 0000 0000/BA 06 0000 0090
Or a 12 Core 5900X that I have it setup as standard would result in these replace values, BA 0C 0000 0000/BA 0C 0000 0090
EXAMPLE
Power Gadget App
AMD.Power.Gadget.app.zip
OpenCore EFI Update V0.8.0 - 18/04/2022
- Lilu 1.6.0,
- AppleALC 1.7.1,
- WhateverGreen 1.5.8,
- VirtualSMC 1.2.9,
- RestrictEvents 1.0.7,
- LucyRTL8125Ethernet 1.1.0
- SMCAMDProcessor 0.7
- AppleMCEReporterDisabler 1.2
- SmallTreeIntel812576Ethernet 1.3.0
- New Universal AMD Patches Monterey 12.0 Compatible,
- 2.5Ghz Ethernet Auto Negotiation Fixed,
- Memory Mapping is now Being done via RestrictEvents,
- About This Mac now displays the correct AMD Processor info done via RestrictEvents,
- Plus other minor tweaks and changes to the config.
- Advanced -> APM Configuration -> Power On By PCIe -> Disabled
CoreCount | Hexadecimal |
6 Core | 06 |
8 Core | 08 |
12 Core | 0C |
16 Core | 10 |
32 Core | 20 |
EXAMPLE
Power Gadget App
v0.8.0
- Added support for early log preservation
- Switched to Python 3 in scripts (use python /path/to/script to force Python 2)
- Added ForceAquantiaEthernet for Aquantia AQtion AQC-107s based 10GbE network cards support, thx @Mieze and @Shikumo
- Updated builtin firmware versions for SMBIOS and the rest
- Added Misc -> Serial section to customise serial port properties
- Added CustomPciSerialDevice quirk for XNU to correctly recognise customised external serial devices
ATTACHMENTSApril
