Can't upgrade to Monterey 12.2
tmk
Hello, I'm running 12.1 on opencore 0.7.5. Do you have any idea why 12.2 update is not showing up in the Software Update ? Thx
Make sure SecureBootModel is set to Default in your config and SIP is enabled.
Solution
askunk
Hey Shanee,
Sorry to bother you. I have the same problem (using an EFI you sent me in December (AudioGod's). The 12.2 update does not appear in Sys Prefs.
SecureBootModel is "Default" (but AppleSecureBoot is "false") and SIP is enabled.
Any suggestions? I have a bootable USB with the 12.2 full installer. Shall I just proceed with it?
Thank you in advance :)
@askunk Try running this in Terminal,
softwareupdate -lia
@askunk In that case you can use the installer. Just install over your existing partition without formatting and it'll update the system as normal.
