Try going into your BIOS boot menu and selecting the OpenCore on the primary drive where you have MacOS installed.
Bios only shows one boot device which is the install USB, if removed the system won't boot into anything it just hangsTry going into your BIOS boot menu and selecting the OpenCore on the primary drive where you have MacOS installed.
When you boot from the USB and installed MacOs on your main drive, you will need to unhide the EFI partition of that main drive and copy over the EFI folder from the USB drive. Then you will boot normally.Bios only shows one boot device which is the install USB, if removed the system won't boot into anything it just hangs
Other issues I am running into:
I'm unable to load the itlwm.kext file into /System/Library/Extensions/ to get wifi to work. I've tried using cp and also tried dragging and dropping into the directory. The directory seems like it's read only
When trying to run boot camp I am getting an error telling me to remove external drives before proceeding. This problem persists even after I unmount and remove the install USB
So overwrite the existing EFI that is on the MacOS disk with the one from the install disk? Do I need to keep anything from the existing EFI folder that the installer created?When you boot from the USB and installed MacOs on your main drive, you will need to unhide the EFI partition of that main drive and copy over the EFI folder from the USB drive. Then you will boot normally.
Sent from my SM-N986U using Tapatalk
I usually leave what's in there which should just be a MacOs or similar named folder. And copy over the OC and boot foldersSo overwrite the existing EFI that is on the MacOS disk with the one from the install disk? Do I need to keep anything from the existing EFI folder that the installer created?
Got the boot problem and the wifi working.So overwrite the existing EFI that is on the MacOS disk with the one from the install disk? Do I need to keep anything from the existing EFI folder that the installer created?
csrutil enable --without kext
sudo kextload /Library/Extensions/itlwm.kext
Oops, I replaced the whole thing. Live and learn, I guess I'll see if it causes any issues!I usually leave what's in there which should just be a MacOs or similar named folder. And copy over the OC and boot folders
00:000 00:000 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:042 00:042 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:077 00:035 AAPL: #[EB|H:IS] 0
00:119 00:041 AAPL: #[EB|LOG:INIT] 2022-01-20T19:13:45
00:157 00:038 AAPL: #[EB|VERSION] <"boot.efi 495.100.13~59 (Official), built 2021-05-08T05:55:31-0700">
00:192 00:034 AAPL: #[EB|BUILD] <"BUILD-INFO[302]:{"DisplayName":"boot.efi","DisplayVersion":"495.100.13~59","RecordUuid":"D6A721F0-B0AE-4BF3-9BA5-48DCAA5566E6","BuildTime":"2021-05-08T05:55:31-0700","ProjectName":"efiboot","ProductName":"boot.efi","SourceVersion":"495.100.13","BuildVersion":"59","BuildConfiguration":"Release","BuildType":"Official"}">
00:232 00:039 AAPL: #[EB.CFG.DEV|!] Err(0xE) <- RT.GV booter-strict-xmlparser 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:275 00:042 AAPL: #[EB|CFGEV] r5 0x0 0x0
00:321 00:045 AAPL: #[EB|H:IS] 0
00:361 00:040 AAPL: #[EB|WL:MODE] 0
00:385 00:023 AAPL: #[EB|CFG:ARG] boot-save-log 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) default
00:409 00:024 AAPL: #[EB|CFG:ARG] wake-save-log 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) default
00:440 00:031 AAPL: #[EB|CFG:ARG] console 0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) default
00:466 00:025 AAPL: #[EB|CFG:ARG] serial 0x0000000000000001 (0x0000000000000001 < 0x0000000000000000) default
00:492 00:025 AAPL: #[EB|CFG:ARG] embed-log-dt 0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) default
00:569 00:076 AAPL: #[EB|CFG:ARG] timestamps 0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) default
00:606 00:036 AAPL: #[EB|CFG:ARG] log-level 0x0000000000000001 (0x0000000000000001 & 0x0000000000000021) default
00:650 00:044 AAPL: #[EB|CFG:ARG] breakpoint 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
00:686 00:036 AAPL: #[EB|CFG:ARG] kc-read-size 0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) default
00:726 00:039 AAPL: #[EB|H:IS] 0
00:763 00:036 AAPL: #[EB|WL] 0 0 0x01 0x01 0 0x00
00:808 00:045 AAPL: #[EB|BRD:NV] Mac-27AD2F918AE68F61
00:845 00:037 AAPL: #[EB|WL] 0 0 0x01 0x01 2 0x00
00:884 00:038 AAPL: #[EB.BST.IDT|+]
00:925 00:041 AAPL: #[EB|BM] J160AP
00:965 00:039 AAPL: #[EB.BST.IDT|-]
01:010 00:045 AAPL: #[EB|WL] 0 0 0x01 0x01 3 0x00
01:093 00:083 AAPL: #[EB|WL] 0 0 0x01 0x01 4 0x00
01:178 00:084 AAPL: #[EB|BRD:NV] Mac-27AD2F918AE68F61
01:261 00:083 AAPL: #[EB|WL] 0 0 0x01 0x01 5 0x00
01:339 00:078 AAPL: #[EB.H.CHK|BM] 0x0000000000000000
01:421 00:082 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:500 00:079 AAPL: #[EB|WL] 0 0 0x01 0x01 23 0x0E
01:585 00:084 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:665 00:079 AAPL: #[EB|WL] 0 0 0x01 0x01 24 0x0E
01:746 00:081 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:806 00:059 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:851 00:044 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:896 00:045 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
01:940 00:044 AAPL: #[EB|H:NOT]
01:985 00:044 AAPL: #[EB|SB] 0x1
02:033 00:048 AAPL: #[EB.B.MN|BM:+SB]
02:078 00:045 AAPL: #[EB|LIMGP] Acpi(PNP0A03,0)/Pci(1|1)/Pci(0|0)/?[ 0x83 0x17 0x10 0x0 0x1 0x0 0x0 0x0 0x0 0x25 0x38 0xB5 0x11 0xB4 0x75 0xA6 ]/HD(Part2,Sig4F24998A-9B46-4235-B4C3-85C7C4756F37)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842)
02:124 00:045 AAPL: #[EB|LIMG:FP] \160C8E14-FBE6-4AB6-9C03-402D73E7A1DD\System\Library\CoreServices\boot.efi
02:169 00:045 AAPL: #[EB|LIMG:OPT]
02:219 00:049 AAPL: #[EB.OPT.LXF|F] <"\\160C8E14-FBE6-4AB6-9C03-402D73E7A1DD\\System\\Library\\CoreServices\\com.apple.Boot.plist">
02:264 00:045 AAPL: #[EB.LD.LF|IN] 0 1 <"\\160C8E14-FBE6-4AB6-9C03-402D73E7A1DD\\System\\Library\\CoreServices\\com.apple.Boot.plist"> <"0">
02:312 00:048 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\160C8E14-FBE6-4AB6-9C03-402D73E7A1DD\\System\\Library\\CoreServices\\com.apple.Boot.plist">
02:361 00:049 AAPL: #[EB.OPT.LXF|LF!] Err(0xE)
02:409 00:048 AAPL: #[EB.OPT.LXF|F] <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist">
02:459 00:049 AAPL: #[EB.LD.LF|IN] 0 1 <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist"> <"0">
02:515 00:056 AAPL: #[EB|KF] <"">
02:564 00:049 AAPL: #[EB|MBA:CL] <"">
04:410 01:846 AAPL: #[EB|MBA:NV] <"agdpmod=ignore -v keepsyms=1 slide=134">
04:460 00:049 AAPL: #[EB|MBA:KF] <"">
04:516 00:055 AAPL: #[EB|MBA:OUT] <"agdpmod=ignore -v keepsyms=1 slide=134 chunklist-security-epoch=0 -chunklist-no-rev2-dev">
04:565 00:049 AAPL: #[EB|LOG:VERBOSE] 2022-01-20T19:13:49
04:618 00:052 AAPL: #[EB.CSR.S|VAR] 0x00000040
04:667 00:049 AAPL: #[EB|OPT:BM] 0x280102
04:861 00:193 AAPL: #[EB.OPT.LXF|F] <"\\160C8E14-FBE6-4AB6-9C03-402D73E7A1DD\\System\\Library\\CoreServices\\PlatformSupport.plist">
04:955 00:094 AAPL: #[EB.LD.LF|IN] 0 1 <"\\160C8E14-FBE6-4AB6-9C03-402D73E7A1DD\\System\\Library\\CoreServices\\PlatformSupport.plist"> <"0">
05:040 00:085 AAPL: #[EB|B:VAw]
05:131 00:090 AAPL: #[EB|P:CPR] N
05:217 00:086 AAPL: #[EB|P:MPI] N
05:304 00:086 AAPL: #[EB|P:BPI] N
05:396 00:092 AAPL: #[EB|KMR] 371101696
05:489 00:093 AAPL: #[EB.CS.CSKSD|+]
05:560 00:070 AAPL: #[EB.CS.CSKSD|!] Err(0xE) <- RT.GV boot-info-payload 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF
05:605 00:044 AAPL: #[EB|WL] 0 0 0x01 0x01 6 0x0E
05:656 00:051 AAPL: #[EB.CS.LFC|+]
05:701 00:045 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\Caches\\com.apple.corestorage\\EncryptedRoot.plist.wipekey"> <"0">
05:752 00:051 AAPL: #[EB.FS.AGSVH|PU] 160C8E14-FBE6-4AB6-9C03-402D73E7A1DD
05:799 00:046 AAPL: #[EB.FS.AGSVH|!] Err(0xE) <- BS.LocHB 59D76AE4-37E3-55A7-B460-EF13D46E6020
05:845 00:046 AAPL: #[EB.G.CS|-?] Ok(0)
05:897 00:052 AAPL: #[EB.LD.LF|IN] 0 1 <"<null string>"> <"1">
05:954 00:056 AAPL: #[EB.B.SBS|SZ] 739896
07:855 01:901 AAPL: #[EB|B:SHA] <c017595ae89e9e8539e960c9e22eae18f7daa006>
07:903 00:048 AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
07:951 00:048 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
08:050 00:098 AAPL: #[EB.WL.PWLFRTC|NONE]
08:110 00:060 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFRTC
08:169 00:058 AAPL: #[EB.LD.LKC|D] <"boot\System\Library\KernelCollections\BootKernelExtensions.kc.development">
08:231 00:061 AAPL: #[EB.LD.LF|IN] 0 1 <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.development"> <"0">
08:291 00:060 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.development">
08:360 00:068 AAPL: #[EB.LD.LKC|R.2] <"boot\System\Library\KernelCollections\BootKernelExtensions.kc">
08:420 00:060 AAPL: #[EB.LD.LF|IN] 0 1 <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc"> <"0">
09:345 00:925 AAPL: #[EB|SB] 0x1
09:406 00:061 AAPL: #[EB|SB:SBGMFNS] j160ap.im4m
09:465 00:059 AAPL: #[EB|SB:MF] boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.j160ap.im4m
09:533 00:068 AAPL: #[EB.LD.LF|IN] 0 1 <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.j160ap.im4m"> <"0">
09:742 00:208 AAPL: #[EB|SB:MKRN]
09:814 00:072 AAPL: #[EB.LD.LKFS|-?] Ok(0)
09:879 00:064 AAPL: #[EB.LD.LKC|-?] Ok(0)
09:947 00:067 AAPL: #[EB|FWFM] 0x00000008FFFFFF7F
11:829 01:882 AAPL: #[EB|FWFT] 0x00000008FDAFF066
11:891 00:061 AAPL: #[EB|BST:REV1]
11:954 00:063 AAPL: #[EB|CSR:OUT] 0x00000040
12:018 00:063 AAPL: #[EB.BST.FBS|+]
12:084 00:065 AAPL: #[EB.BST.FBS|ADSZ] 0
12:155 00:070 AAPL: #[EB.BST.FBS|KSSZ] 0
12:215 00:060 AAPL: #[EB|SB:SBGMFNS] j160ap.im4m
12:278 00:062 AAPL: #[EB|RHF] usr\standalone\OS.dmg.root_hash
12:343 00:065 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.j160ap.im4m">
12:510 00:166 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">
12:579 00:068 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash.j160ap.im4m"> <"0">
12:636 00:056 AAPL: #[EB.BST.FBS|RHPSZ] 229
12:701 00:065 AAPL: #[EB.BST.FBS|RHMSZ] 3626
12:775 00:074 AAPL: #[EB.B.WFDW|!WF] Err(0xE) 0
12:850 00:074 AAPL: #[EB|LOGT] 2022-01-20T19:13:57
12:932 00:081 AAPL: #[EB|LOG:EXITBS:START] 2022-01-20T19:13:57
Reset your BIOS and try these settings. When updating the BIOS it can reset to default.
If that does not work use the clean EFI for 0.7.7 from and try booting.
I'd be upgrading from Big Sur so I likely won't notice any differenceWhat OS are you upgrading from?
The only issue is with 1GB Ethernet which has been broken in the public releases of MacOS Big Sur and Monterey.
Other than that everything else works properly.
Hello,
Do you use any application to a complete backup of the entire system that restores the entire disk without problem? Which app is the best? Thanks
Hello,
I built audiogods build almost identical a few months ago.
Ryzen 5900x
Asus ROG Strix X570-E Gaming
AMD Radeon 6800xt
Big Sur OS
until recently everything ran without any problem.
Then I had some crashes under Windows, which became so extreme that I sometimes couldn't manage to make any settings in the BIOS, because it was already crashing there. I then moved the RAM from slots 1 and 3 to 1 and 2 (single channel) and did a BIOS update to ver. 4021.
At some point, however, I seem to have caused my macOS to no longer boot. My guess is due to the BIOS update.
After selecting the partition in OpenCore, it boots but hangs at 50% or 75% of the progress bar and does not continue to load, even after 20 minutes. The funny thing is: After about 5 minutes, the mouse pops up, but Apple logo and 50% progress bar are still there and it doesn't continue from here.
I then re-injected the EFI, made all the settings suggested by audiogod in the BIOS and fired up Open Core debugging, but can't make sense of where the error lies.
I would be very happy if someone could offer me a solution.
Next step would be to send in the motherboard, since there is obviously a problem with the RAM here and presumably slots are defective and/or reinstall macOS.
Many thanks in advance!
LOG:
Code:00:000 00:000 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82 00:042 00:042 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82 00:077 00:035 AAPL: #[EB|H:IS] 0 00:119 00:041 AAPL: #[EB|LOG:INIT] 2022-01-20T19:13:45 00:157 00:038 AAPL: #[EB|VERSION] <"boot.efi 495.100.13~59 (Official), built 2021-05-08T05:55:31-0700"> 00:192 00:034 AAPL: #[EB|BUILD] <"BUILD-INFO[302]:{"DisplayName":"boot.efi","DisplayVersion":"495.100.13~59","RecordUuid":"D6A721F0-B0AE-4BF3-9BA5-48DCAA5566E6","BuildTime":"2021-05-08T05:55:31-0700","ProjectName":"efiboot","ProductName":"boot.efi","SourceVersion":"495.100.13","BuildVersion":"59","BuildConfiguration":"Release","BuildType":"Official"}"> 00:232 00:039 AAPL: #[EB.CFG.DEV|!] Err(0xE) <- RT.GV booter-strict-xmlparser 7C436110-AB2A-4BBB-A880-FE41995C9F82 00:275 00:042 AAPL: #[EB|CFGEV] r5 0x0 0x0 00:321 00:045 AAPL: #[EB|H:IS] 0 00:361 00:040 AAPL: #[EB|WL:MODE] 0 00:385 00:023 AAPL: #[EB|CFG:ARG] boot-save-log 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) default 00:409 00:024 AAPL: #[EB|CFG:ARG] wake-save-log 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) default 00:440 00:031 AAPL: #[EB|CFG:ARG] console 0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) default 00:466 00:025 AAPL: #[EB|CFG:ARG] serial 0x0000000000000001 (0x0000000000000001 < 0x0000000000000000) default 00:492 00:025 AAPL: #[EB|CFG:ARG] embed-log-dt 0x0000000000000000 (0x0000000000000000 < 0x0000000000000000) default 00:569 00:076 AAPL: #[EB|CFG:ARG] timestamps 0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) default 00:606 00:036 AAPL: #[EB|CFG:ARG] log-level 0x0000000000000001 (0x0000000000000001 & 0x0000000000000021) default 00:650 00:044 AAPL: #[EB|CFG:ARG] breakpoint 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default 00:686 00:036 AAPL: #[EB|CFG:ARG] kc-read-size 0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) default 00:726 00:039 AAPL: #[EB|H:IS] 0 00:763 00:036 AAPL: #[EB|WL] 0 0 0x01 0x01 0 0x00 00:808 00:045 AAPL: #[EB|BRD:NV] Mac-27AD2F918AE68F61 00:845 00:037 AAPL: #[EB|WL] 0 0 0x01 0x01 2 0x00 00:884 00:038 AAPL: #[EB.BST.IDT|+] 00:925 00:041 AAPL: #[EB|BM] J160AP 00:965 00:039 AAPL: #[EB.BST.IDT|-] 01:010 00:045 AAPL: #[EB|WL] 0 0 0x01 0x01 3 0x00 01:093 00:083 AAPL: #[EB|WL] 0 0 0x01 0x01 4 0x00 01:178 00:084 AAPL: #[EB|BRD:NV] Mac-27AD2F918AE68F61 01:261 00:083 AAPL: #[EB|WL] 0 0 0x01 0x01 5 0x00 01:339 00:078 AAPL: #[EB.H.CHK|BM] 0x0000000000000000 01:421 00:082 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82 01:500 00:079 AAPL: #[EB|WL] 0 0 0x01 0x01 23 0x0E 01:585 00:084 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82 01:665 00:079 AAPL: #[EB|WL] 0 0 0x01 0x01 24 0x0E 01:746 00:081 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82 01:806 00:059 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82 01:851 00:044 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82 01:896 00:045 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82 01:940 00:044 AAPL: #[EB|H:NOT] 01:985 00:044 AAPL: #[EB|SB] 0x1 02:033 00:048 AAPL: #[EB.B.MN|BM:+SB] 02:078 00:045 AAPL: #[EB|LIMGP] Acpi(PNP0A03,0)/Pci(1|1)/Pci(0|0)/?[ 0x83 0x17 0x10 0x0 0x1 0x0 0x0 0x0 0x0 0x25 0x38 0xB5 0x11 0xB4 0x75 0xA6 ]/HD(Part2,Sig4F24998A-9B46-4235-B4C3-85C7C4756F37)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842) 02:124 00:045 AAPL: #[EB|LIMG:FP] \160C8E14-FBE6-4AB6-9C03-402D73E7A1DD\System\Library\CoreServices\boot.efi 02:169 00:045 AAPL: #[EB|LIMG:OPT] 02:219 00:049 AAPL: #[EB.OPT.LXF|F] <"\\160C8E14-FBE6-4AB6-9C03-402D73E7A1DD\\System\\Library\\CoreServices\\com.apple.Boot.plist"> 02:264 00:045 AAPL: #[EB.LD.LF|IN] 0 1 <"\\160C8E14-FBE6-4AB6-9C03-402D73E7A1DD\\System\\Library\\CoreServices\\com.apple.Boot.plist"> <"0"> 02:312 00:048 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"\\160C8E14-FBE6-4AB6-9C03-402D73E7A1DD\\System\\Library\\CoreServices\\com.apple.Boot.plist"> 02:361 00:049 AAPL: #[EB.OPT.LXF|LF!] Err(0xE) 02:409 00:048 AAPL: #[EB.OPT.LXF|F] <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist"> 02:459 00:049 AAPL: #[EB.LD.LF|IN] 0 1 <"Library\\Preferences\\SystemConfiguration\\com.apple.Boot.plist"> <"0"> 02:515 00:056 AAPL: #[EB|KF] <""> 02:564 00:049 AAPL: #[EB|MBA:CL] <""> 04:410 01:846 AAPL: #[EB|MBA:NV] <"agdpmod=ignore -v keepsyms=1 slide=134"> 04:460 00:049 AAPL: #[EB|MBA:KF] <""> 04:516 00:055 AAPL: #[EB|MBA:OUT] <"agdpmod=ignore -v keepsyms=1 slide=134 chunklist-security-epoch=0 -chunklist-no-rev2-dev"> 04:565 00:049 AAPL: #[EB|LOG:VERBOSE] 2022-01-20T19:13:49 04:618 00:052 AAPL: #[EB.CSR.S|VAR] 0x00000040 04:667 00:049 AAPL: #[EB|OPT:BM] 0x280102 04:861 00:193 AAPL: #[EB.OPT.LXF|F] <"\\160C8E14-FBE6-4AB6-9C03-402D73E7A1DD\\System\\Library\\CoreServices\\PlatformSupport.plist"> 04:955 00:094 AAPL: #[EB.LD.LF|IN] 0 1 <"\\160C8E14-FBE6-4AB6-9C03-402D73E7A1DD\\System\\Library\\CoreServices\\PlatformSupport.plist"> <"0"> 05:040 00:085 AAPL: #[EB|B:VAw] 05:131 00:090 AAPL: #[EB|P:CPR] N 05:217 00:086 AAPL: #[EB|P:MPI] N 05:304 00:086 AAPL: #[EB|P:BPI] N 05:396 00:092 AAPL: #[EB|KMR] 371101696 05:489 00:093 AAPL: #[EB.CS.CSKSD|+] 05:560 00:070 AAPL: #[EB.CS.CSKSD|!] Err(0xE) <- RT.GV boot-info-payload 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF 05:605 00:044 AAPL: #[EB|WL] 0 0 0x01 0x01 6 0x0E 05:656 00:051 AAPL: #[EB.CS.LFC|+] 05:701 00:045 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\Caches\\com.apple.corestorage\\EncryptedRoot.plist.wipekey"> <"0"> 05:752 00:051 AAPL: #[EB.FS.AGSVH|PU] 160C8E14-FBE6-4AB6-9C03-402D73E7A1DD 05:799 00:046 AAPL: #[EB.FS.AGSVH|!] Err(0xE) <- BS.LocHB 59D76AE4-37E3-55A7-B460-EF13D46E6020 05:845 00:046 AAPL: #[EB.G.CS|-?] Ok(0) 05:897 00:052 AAPL: #[EB.LD.LF|IN] 0 1 <"<null string>"> <"1"> 05:954 00:056 AAPL: #[EB.B.SBS|SZ] 739896 07:855 01:901 AAPL: #[EB|B:SHA] <c017595ae89e9e8539e960c9e22eae18f7daa006> 07:903 00:048 AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82 07:951 00:048 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV 08:050 00:098 AAPL: #[EB.WL.PWLFRTC|NONE] 08:110 00:060 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFRTC 08:169 00:058 AAPL: #[EB.LD.LKC|D] <"boot\System\Library\KernelCollections\BootKernelExtensions.kc.development"> 08:231 00:061 AAPL: #[EB.LD.LF|IN] 0 1 <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.development"> <"0"> 08:291 00:060 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.development"> 08:360 00:068 AAPL: #[EB.LD.LKC|R.2] <"boot\System\Library\KernelCollections\BootKernelExtensions.kc"> 08:420 00:060 AAPL: #[EB.LD.LF|IN] 0 1 <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc"> <"0"> 09:345 00:925 AAPL: #[EB|SB] 0x1 09:406 00:061 AAPL: #[EB|SB:SBGMFNS] j160ap.im4m 09:465 00:059 AAPL: #[EB|SB:MF] boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.j160ap.im4m 09:533 00:068 AAPL: #[EB.LD.LF|IN] 0 1 <"boot\\System\\Library\\KernelCollections\\BootKernelExtensions.kc.j160ap.im4m"> <"0"> 09:742 00:208 AAPL: #[EB|SB:MKRN] 09:814 00:072 AAPL: #[EB.LD.LKFS|-?] Ok(0) 09:879 00:064 AAPL: #[EB.LD.LKC|-?] Ok(0) 09:947 00:067 AAPL: #[EB|FWFM] 0x00000008FFFFFF7F 11:829 01:882 AAPL: #[EB|FWFT] 0x00000008FDAFF066 11:891 00:061 AAPL: #[EB|BST:REV1] 11:954 00:063 AAPL: #[EB|CSR:OUT] 0x00000040 12:018 00:063 AAPL: #[EB.BST.FBS|+] 12:084 00:065 AAPL: #[EB.BST.FBS|ADSZ] 0 12:155 00:070 AAPL: #[EB.BST.FBS|KSSZ] 0 12:215 00:060 AAPL: #[EB|SB:SBGMFNS] j160ap.im4m 12:278 00:062 AAPL: #[EB|RHF] usr\standalone\OS.dmg.root_hash 12:343 00:065 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.j160ap.im4m"> 12:510 00:166 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0"> 12:579 00:068 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash.j160ap.im4m"> <"0"> 12:636 00:056 AAPL: #[EB.BST.FBS|RHPSZ] 229 12:701 00:065 AAPL: #[EB.BST.FBS|RHMSZ] 3626 12:775 00:074 AAPL: #[EB.B.WFDW|!WF] Err(0xE) 0 12:850 00:074 AAPL: #[EB|LOGT] 2022-01-20T19:13:57 12:932 00:081 AAPL: #[EB|LOG:EXITBS:START] 2022-01-20T19:13:57
