How to disable SIP in Monterey
dramsey
I've been trying to do this all afternoon so I can try Kepler Patcher, with no luck.
In config.plist, I've set csr-active-config to "00000000", and also added "csr-active-config" as a parameter in NVRAM->Delete->7C436110-AB2A-4BBB-A880-FE41995C9F82,
No joy. On each reboot, "csrutil status" still returns "Enabled".
There's also a handy key in the file called "AllowToggleSip", which, if enabled, should show an SIP toggle in the OpenCore boot picker. Nope, that doesn't have any effect either. If I had any other volumes with an EFI mounted I'd swear I was booting from another drive...
Boot to the recovery, launch Terminal and run csrutil disable. In OC 00000000 is SIP enabled.
It works ;) With OpenCore it acts more like a real Mac.
dramsey
It did in fact work-- I also finally figured out that I can simply tap the space bar to get the "SIP Toggle", which also works.
What doesn't work-- Kepler Patcher V2, which in the two attempts I've made has rendered the machine unbootable each time. After two failed boot attempts it falls back to Recovery, from which I re-installed Monterey 12.1. Maybe it's an AMD thing?
It should work fine on AMD. You'll also need to disable authenticed root in the recovery too. csrutil authenticated-root disable
Correct yes.
dramsey
Sadly, evne with:
  • SIP disabled
  • Authenticated root disabled
  • SecureBootModel set to "Disabled" in config.plist...
...running Kepler Patcher 2.0 still results in an unbeatable system. The progress bar gets about halfway across before rebooting.
