here is my config which is working on 11.6 but with update to 12 it is not working. if you fix this for me. i will appreciate it.You'll need to update OpenCore to 0.7.5 and make sure you've got the latest AMD patches. Update any kexts while you're at it and the update should work without issues.
If you're struggling to update the EFI, zip your current working version and upload it here and I'll update it for you.
Hi Shaneee, Here is my working EFI folder, It is OC 0.7.4 version, Have a look thank you.You'll need to update OpenCore to 0.7.5 and make sure you've got the latest AMD patches. Update any kexts while you're at it and the update should work without issues.
I updated Open Core to 0.7.5 and included the lastest patches but stil not booting Machitosh HD, Bigsur 11.6.1 is booting with no trouble , Here is EFI folder. Thank you in advance.You'll need to update OpenCore to 0.7.5 and make sure you've got the latest AMD patches. Update any kexts while you're at it and the update should work without issues.
Hi Shanee, I somehow managed it and upgrated to Monterey. Yes I know they are mixed but I also had tried only the latest 16 fix but it didn't worked I just used your previous sent EFI for kingraptor88 and changed parameters for my system and it worked perfectYour kernel patches are a mix of old and new. You also didn't have ProvideCurrentCpuInfo enabled. Replace your config with this one.
Thank you, You are a life saver
Thank you, i will check it.Biggest issue was missing the updated kernel patches.
One more thing, do you know how to make opencore gui enable? i failed after some testsBiggest issue was missing the updated kernel patches.
Aluveitie, thank you very much!@Jerry Han Looks like you're still using the old kernel patches, you should update to the new ones and follow the README here: https://github.com/AMD-OSX/AMD_Vanilla
