ERROR during direct upgrade from Bigsur 11.6.1 to Monterey
eye
Hi there I just downloaded Monterey using System software update and tried to upgrade but it stucked when system rebooted and Machintosh HD selected. I added the log file , any suggestions?
  • opencore-2021-11-09-120555.txt
You'll need to update OpenCore to 0.7.5 and make sure you've got the latest AMD patches. Update any kexts while you're at it and the update should work without issues.
If you're struggling to update the EFI, zip your current working version and upload it here and I'll update it for you.
kingraptor88
here is my config which is working on 11.6 but with update to 12 it is not working. if you fix this for me. i will appreciate it.
Biggest issue was missing the updated kernel patches.
eye
Hi Shaneee, Here is my working EFI folder, It is OC 0.7.4 version, Have a look thank you.
eye
I updated Open Core to 0.7.5 and included the lastest patches but stil not booting Machitosh HD, Bigsur 11.6.1 is booting with no trouble , Here is EFI folder. Thank you in advance.
Your kernel patches are a mix of old and new. You also didn't have ProvideCurrentCpuInfo enabled. Replace your config with this one.
eye
Hi Shanee, I somehow managed it and upgrated to Monterey. Yes I know they are mixed but I also had tried only the latest 16 fix but it didn't worked I just used your previous sent EFI for kingraptor88 and changed parameters for my system and it worked perfect :D Thank you, You are a life saver :D
One more thing, do you know how to make opencore gui enable? i failed after some tests
You need to include OpenCanopy.efi in the Drivers folder and in UEFI -> Drivers. You'll also need to make sure you've got the Resources folder upto date from the latest Release.
Then set the following,
  • Misc -> Boot -> PickerMode = External
  • Misc -> Boot -> PickerVariant = Auto
Remove SMCAMDProcessor.kext and AMDRyzenCPUPowerManagement.kext from your config.
kingraptor88
finally i got updated to 12.0.1, thanks bro.
RyzeCooker
"Remove SMCAMDProcessor.kext and AMDRyzenCPUPowerManagement.kext from your config."
So aren't these recommended anymore for Monterey?
AMDRyzenCPUPowerManagement.kext works just fine for me on Monterey
RyzeCooker
Yeah, I have 'm too with no issues. :)
Jerry Han
