Can't upgrade to monterey
tatofuma
I downloaded update, start installation, I arrive at reboot and I find myself with the classic Macintosh Hd disk at boot. I start that but nothing, in a few seconds the pc restarts. After several attempts I start the standard mac hd, but I always end up with big sur.
I have OC 0.7.4 and set securebootmodel to default
System specs? If it's a MSI motherboard that'll be the issue.
In that case make sure you've got the latest patches from the AMD_Vanilla GitHub and you've set them up correctly. Also update your kexts. Many were updated for macOS 12 support.
pampas
ok. thanks. I have B450 itx. I don't have any problem till now
tatofuma
All update and config. Securebootmodel must be "disabled"?
SecureBootModel should be set to Default.
Clear the NVRAM and start the update from the System Preferences pane again.
RyzeCooker
Mine is set to Disabled as well and my current EFI (0.7.4) on my Monterey test stick booted fine and fast. I'm confused which setting is best, there seem to be conflicting suggestions? Wanted to give the upgrade to Monterey a go this weekend.
I've seen it stick there before after a failed update. If you've got everything updated then download the app from the App Store and use createinstallmedia to make a bootable USB.
sudo /Applications/Install\ macOS\ Monterey.app/Contents/Resources/createinstallmedia --volume /Volumes/MyVolume
Replace MyVolume with the name of your USB drive.
tatofuma
try to update with usb installer..nothing to do.
Try a fresh install, notingh... I cant install monterey.
tatofuma
I have used @AudioGod Efi for install Monterey, everything work. Return to use my big sur efi, same, all work. Only a problem: when I boot, first time not bot, auto restart. Then, second boot is fine. Every time I have to boot two time for go to desktop
