Is this something anyone here had managed to fix? I’m using an RX 5700XT. I am on Monterey right now but had the same issue on Big Sur.
HDMI or DP? Because I'm in Monterey too at 144hz.Is this something anyone here had managed to fix? I’m using an RX 5700XT. I am on Monterey right now but had the same issue on Big Sur.
my AOC monitor connected directly to rx 5700xt via DP and set at 144hz with no blackouts, check your DP cable
Oh forgot to reply. My monitor only does variable refresh over DP. HDMI is capped at 60.Have you tried with HDMI?
Quite possibly.To clarify, basically everything above this current refresh rate results in this issue. I was also wondering though, I did flash my 5700 with 5700XT firmware. Could this be the culprit?
Only barely saw a benefit. Haven't noticed anything flakey on it and it is a dual bios card so no risk here.Quite possibly.
I honestly can't understand what you expected to gain with that flashing. Do you even see any meaningful performance increase, worthy of risking the entire card..?
It's not like all those disabled compute units will suddenly spring to life with new firmware. Even if that could somehow happen, there's a reason chip had those silicon parts disabled - if they were working properly, chip would be sold as pricier 5700 XT.
Then switch to original BIOS for 5700 and see if black screens are gone. If not, something else is an issue.Only barely saw a benefit. Haven't noticed anything flakey on it and it is a dual bios card so no risk here.
I would try looking into your max resolution and refresh rate. I truly think it's just a Monterey beta issue (mentioned here), probably with the Max hz your device supported. The few times I've used my Mac with my monitor, I know it works at 60hz but I usually use it at 16:9 in pbp mode which is also 120hz.
Hi... its all about your monitor. (M27Q)... Ive been experience that issue today. I just recieve today a Gigabyte M27Q and ive been getting mad all day... because as soon I change Herts over 120 i get a black screen.... Changing monitor to my old monitor and at same settings get signal straight away... So after a lot os testing the result is that M27Q is the problem... I updated the firmware of the monitor from F02 to F04 and didnt solve the problem.... HDMI works but DP NO.
Hope it helps and sorry for my poor english...
Cheers!
