Im not understanding about the algrey patches. Where di I get them?Did you setup the patches correctly? See here, https://forum.amd-osx.com/index.php?threads/new-amd-macos-corecount-patch-information.1948/
Im attaching my config.plist. If you could help Id really appreciate it.Im not understanding about the algrey patches. Where di I get them?
Gigabyte B450M DS3H V2That entire EFI is a mess... What are your specs?
656e2d55533a30
. You may need to reset the NVRAM to get it to change. There should be an option in the boot picker before you boot into the macOS Installer.Im typing this from my install. Seems a bit choppy. I wonder if I should do Catalina instead? is there a post install I need to do?
Also no soundIm typing this from my install. Seems a bit choppy. I wonder if I should do Catalina instead? is there a post install I need to do?
layout 1, 2, 3, 5, 7, 11, 12, 13, 17, 18, 20, 33, 40, 50, 52, 53, 87, 99
had to go 1 to 50! took a while lol. Only thing now id I cant sign into icloud. I have changed the ROM and serial not sure what else to tryChoppy how?
As for Audio you need to set the layout id with the boot arg alcid=x Replacing x with a layout ID. Your chip supports the following layouts,
Try them one at a time till you get one that works. You'll need to reboot after each change to see any changes.Code:layout 1, 2, 3, 5, 7, 11, 12, 13, 17, 18, 20, 33, 40, 50, 52, 53, 87, 99
went thru the guide. Nothing seems to be working. I get the code on my phone then it disappears back to asking for apple idSee here for iCloud issues, https://dortania.github.io/OpenCore-Post-Install/universal/iservices.html
