Im not understanding about the algrey patches. Where di I get them?Did you setup the patches correctly? See here, https://forum.amd-osx.com/index.php?threads/new-amd-macos-corecount-patch-information.1948/
Im attaching my config.plist. If you could help Id really appreciate it.Im not understanding about the algrey patches. Where di I get them?
Gigabyte B450M DS3H V2That entire EFI is a mess... What are your specs?
Im typing this from my install. Seems a bit choppy. I wonder if I should do Catalina instead? is there a post install I need to do?
Also no soundIm typing this from my install. Seems a bit choppy. I wonder if I should do Catalina instead? is there a post install I need to do?
layout 1, 2, 3, 5, 7, 11, 12, 13, 17, 18, 20, 33, 40, 50, 52, 53, 87, 99
had to go 1 to 50! took a while lol. Only thing now id I cant sign into icloud. I have changed the ROM and serial not sure what else to tryChoppy how?
As for Audio you need to set the layout id with the boot arg alcid=x Replacing x with a layout ID. Your chip supports the following layouts,
Try them one at a time till you get one that works. You'll need to reboot after each change to see any changes.Code:layout 1, 2, 3, 5, 7, 11, 12, 13, 17, 18, 20, 33, 40, 50, 52, 53, 87, 99
went thru the guide. Nothing seems to be working. I get the code on my phone then it disappears back to asking for apple idSee here for iCloud issues, https://dortania.github.io/OpenCore-Post-Install/universal/iservices.html
