1st timer with Ryzen and opencore
That entire EFI is a mess... What are your specs?
Gigabyte B450M DS3H V2
Processor AMD Ryzen 7 3700X 8-Core Processor, 3593 Mhz, 8 Core(s), 16 Logical Processor(s)
64gb RAM
Realtek High Definition Audio
Realtek Gaming GbE Family Controller
AMD Radeon Pro WX 2100
Replace the full EFI folder with this one.
Reactions: Pulsar
In your BIOS, find and enable Above 4G or add the boot arg npci=0x2000 but not both.
In the NVRAM section of the config set prev-lang:kbd to 656e2d55533a30. You may need to reset the NVRAM to get it to change. There should be an option in the boot picker before you boot into the macOS Installer.
Choppy how?
As for Audio you need to set the layout id with the boot arg alcid=x Replacing x with a layout ID. Your chip supports the following layouts,
layout 1, 2, 3, 5, 7, 11, 12, 13, 17, 18, 20, 33, 40, 50, 52, 53, 87, 99
Try them one at a time till you get one that works. You'll need to reboot after each change to see any changes.
Choppy how?
had to go 1 to 50! took a while lol. Only thing now id I cant sign into icloud. I have changed the ROM and serial not sure what else to try
It can take a few attempts sometimes. Try a different serial number and clear the NVRAM in-between attempts.
