I saw it on my dev channel. Not public beta yet.
I’m using dev beta5, it’s just not showing for me when I check for an update. I’m not the only one who’s not getting the update too, very strange
It is not longer showing up. I just booted back into MacOS and the Beta 6 update is gone.
I just saw the update is only for the M1 Chip
For anybody that’s not seeing the beta6 update what you need todo is go into the Config.plist and set the Secure boot model to j160 restart and the update will show up and then disable the SecureBootModel while it’s downloading and let the system do its thing. Using Default/x86legacy or Disabled seems to break the update.
This is the only method that seems to work so far.
Other then that all is working fine and its safe to update just remember the above.
Reactions: Letrom
So simple, thanks.
I had to try twice to get it install. The first time I changed SecureBootModel to “disable”instead of “Disabled”.
Do you see any improvement in graphics performance?
I can’t say I have checked TBH, I got it up and running and had a ton todo. I will check that one later bud. :)
Thanks a lot brother.
After working for several hours, I'm experiencing period of slow down, even typing on safari address bar feel sluggish. All at random. Restart fixes it.
Try resetting your nvram.
already did.
I removed all windows-related drives (4 SATA drives and 1 NVME) and detached all unnecessary USBs.
Leaving only the Razer wireless dongle and the USB soundcard
Hi, I have an Asus X570 TUF Pro WiFi motherboard and I’m having USB dongle mouse lag issues, I want to try this EFI out and see if it fixes my issues, the lag is only present in macOS and with the dongle, works perfect in Windows and on macOS with bluetooth. If I replace the usb map & ethernet kexts along with SMBIOS serial info, do you think this will work? Thanks!
Replace or remove the USBMap.kext and remove the LucyEthernet kext and the EFI will work with a X570 TUF
Hey AG, I noticed a few pages back you mentioned that BigNavi work better with WhateverGreen disabled. What kind of differences have you found it's made?
If your running dual screens it performs much better with WEG disabled, you don’t need any WEG related boot arguments and it just seems smoother as a whole, the only downside is you loose the hdmi output.
Reactions: eduard0
OpenCore 0.7.3 EFI Update (Monterey 12.0 Beta 6 Ready), 7th September 2021
Changes made include,
  • Lilu 1.5.6,
  • AppleALC 1.6.4,
  • WhateverGreen 1.5.3,
  • VirtualSMC 1.2.7,
  • RestrictEvents 1.0.4,
  • LucyRTL8125Ethernet 1.1.0
  • SMCAMDProcessor 0.7
  • New Universal AMD Patches Monterey 12.0 Beta 6 Compatible,
  • OpenCanopy Icons Updated,
  • OpenCore Updated to Revision 0.7.3 (Monterey Beta 6 Ready),
  • 2.5Ghz Ethernet Auto Negotiation Fixed,
Note 1 - If your not using a RX 6800 or any other Navi/BigNavi GPU then remove agdpmod=ignore from the boot arguments.
Note 2 - If you are using Catalina then in the Config.plist under Misc->Security Change SecureBootModel=Default to j160 or Catalina will not boot.
Note 3 - If you are using a 6 or Less Core Ryzen then go into the Config,plist and under PlatformInfo->Generic Change the ProcessorType from 0 to 1537, This will list your CPU info correctly inside About This Mac.
Note 4 - The SmallTreeIntel82576.kext is not working under Monterey 12.0 so if you plan on playing around with the new OS for now make sure you use the 2.5GHz ethernet port instead.
Note 5 - BIOS SETTING CHANGE - Since Bios Revision 4010 Power On By PCIe can break shut down on some peoples builds so ensure the following setting is now set as disabled.
  • Advanced -> APM Configuration -> Power On By PCIe -> Disabled
IMPORTANT PATCH INFO TO SET THE CORRECT CORE COUNT FOR YOUR CPU
Core Count patch needs to be modified to boot your system. Find the two algrey - Force cpuid_cores_per_package patches and alter the Replace value only.
Changing BA000000 0000/BA000000 0090* to BA <CoreCount> 0000 0000/BA <CoreCount> 0000 0090* substituting <CoreCount> with the hexadeciamal value matching your physical core count.
CoreCountHexadecimal
6 Core06
8 Core08
12 Core0C
16 Core10
32 Core20
So for example a 6 Core 5600X would result in these replace values, BA 06 0000 0000/BA 06 0000 0090
Or a 12 Core 5900X that I have it setup as standard would result in these replace values, BA 0C 0000 0000/BA 0C 0000 0090
EXAMPLE
12 Core EXAMPLE
Power Gadget App
AMD.Power.Gadget.app.zip
OpenCore EFI Update V0.7.3 - 07/09/2021
AudioGod,
Thanks for the new EFI. A breeze, as always with your EFI, to configure the processor and iServices.
I just wanted to let you know your core count photos are not showing up.
AudioGod,
I can see them, I have one of the examples as a spoiler now to take up less space.
Reactions: sass
Any way to get MacOS Recovery and Windows recovery to show in the hidden picker section?
Don’t know about windows recovery but MacOS recovery is there, Press Space at the bootpicker
How can you change the name of the processor? I am trying with CPU-Name and it tries but it does not work since the files are in read only.
