Intel I211-AT Alternative to SmallTree
Status
Not open for further replies.
elixir
I211 Gigabit Network Connection:
Vendor ID: 0x8086
Device ID: 0x1539
Subsystem Vendor ID: 0x1458
Subsystem ID: 0xe000
Revision ID: 0x0003
PCIe Link Speed: 2.5 GT/s
PCIe Link Width: x1
Driver: com.amdosx.driver.AppleIGB
BSD Device Name: en1
Maximum Link Speed: 1 Gb/s
Arrakis
Vendor ID: 0x8086
Device ID: 0x1533
Just to confirm that on TRx40 kernel panic directly
Vendor ID: 0x8086
Device ID: 0x1533
Can you share the panic please.
elixir
i have modified a bit the kext due to connection drops and slow opening of safari, chrome and discord apps.
modded:
a. OSBundledRequired' from "Network-Root" to "Root"
b. i210/i211 --> NETIF_F_TSO to "FALSE"
hope can help to those with connection dropped
  • AppleIGB.kext.zip
baronerosso
modded:
No way on Big Sure, always connection drop
Made some modifications to the source based on linux kernel. Seems to work ok so far. Been running with LAN only and WiFi disabled for some times and seems stable.
  • AppleIGB.kext.zip
AudioGod
Good job, It's Working very well now. Im streaming in 4K and the connection is smooth and solid. No stutter, No drops. :)
reinierlazo
need clusters or just the kexts
reinierlazo
I added the kexts and nothing is disconnected as with arguments
baronerosso
no change, connection drops approximately after 15 second, also managing to reconnect by changing the parameters in network preferences
Could BigSure be giving this connection loss problem? Could someone else with BigSure do a check?
Minimum version it’s built to is 11.0 so should work. I can install Big Sur later on my test ssd and take a look.
elixir
this kext no bloatware ;) only for i210 and i211: note: this kext from Shaneee's latest posted kext
tested on Big Sur 11.5.2 and Monterey Beta 6
  • AppleIGB_i210i211.kext.zip
AudioGod
Is this cleaned up version a update to the last cleanup and fixes that @Shaneee did last night?
elixir
yes, the kext from Shaneee and I did some clean-up and test on the two OS
reinierlazo
You should explain better friends because you added the kexts, I restart the nmvram and nothing drops the connection. added the arguments in my config and it still only works for a few seconds
elixir
Works perfect for me Gigabyte X570 AORUS ELITE
  • Subsystem ID: 0xe000
  • Subsystem Vendor ID: 0x1458
by looking at your network preferences, the smalltreeintel82576 driver is already working, you do not need the appleigb driver
reinierlazo
In mine the same. But help the community, not everyone knows what I mean by you. Thanks for your kexts
Arrakis
@Shaneee
Sorry for the little delay, but I had urgent work to complete. And here's the kernel panic report.
  • Archive.zip
@Arrakis It seems that's unrelated to AppleIGB.kext. It looks to be caused by AppleGraphicsControl.kext
Arrakis
To do the test, I have two absolutely identical EFIs just with the difference of kext for the ethernet ports.
The first with the I210.kext (works very well with BigSur by the way)
The second with the Kext AppleIGB.kext
With the first, the Monterey system is very stable. With the second one doing nothing, it's kernel panic for sure.
Status
