Reset your nvramon big sur, immediately after starting the system, a warning about the start ssd disk pops up:
the disk you attached was not readable by this comp
I press any button and it disappears. everything works fine
My 5900X is tuned and itās a review sample so donāt expect to hit my highs without a lot of work and fine tuningI didn't like the performance on catalina (benchmarks cpu results about 5-7 percents lower than your). So I installed big sur but it turned out the same. now about this mac writes that the processor is unknown and the serial number is unavailable and results tne same in catalina.
This has happened because you didnāt read the notes on the update notice or the main page itself.I downloaded your latest efi and got errors on installation. everything was fine with the previous one
CoreCount | Hexadecimal |
6 Core | 06 |
8 Core | 08 |
12 Core | 0C |
16 Core | 10 |
32 Core | 20 |
If itās not working with my EFI using my last or current version and you have set the core count correctly then itās a problem on your end. The EFIs work just fine.with the previous efi does not install big sur 11.5.2
Constantly reboots after the second stage of the boot
What GPU and what NVMe drive?I have the same cpu as your 5900x
Did you remove agdpmod=ignore from the boot arguments?asus strix vega64
ssd adata xpg gammix s5 2tb m.2 nvme
bios settings laid out on page one
Have you made any other changes to the EFI or added anything else kext, driver or SSDT wise?all done
I see what's wrong now, You have lost Kernel info for one of the kexts.I'll try to install it tomorrow. thanks anyway
only config.plistHave you made any other changes to the EFI or added anything else kext, driver or SSDT wise?
OKI see what's wrong now, You have lost Kernel info for one of the kexts.
Whatever your using to edit the config.plist with is messing up the config that's if its not you doing it.
Download the EFI again and add your SMBIOS details, Remove the boot argument and don't do anything else and try again and use PlistEditPro or Xcode to edit the Config with.
PlistEdit Pro
PlistEdit Pro is a handy little tool to edit your Config.plist with among other things.forum.amd-osx.com
In the first screen shot you sent the kext info is missing and in the second screenshot you sent it looks like your installer is locked.OK
I'll do it tomorrow and let you know. thanks again
